ok now ive been told it will but i wanna see what j-body people say lol
Will lambo hinges for a 05 cavi fit on a 95 cavi?
Straight lines are over-rated In My Opinion =]
yes, but you will want to get the supports to match your doors if they are different. ala, if they're coming off a 2 door and you have a 4 door, the supports will be too strong, the other way around and they won't hold the door up.
the lambos were designed for 95-05 so they will fit. like he stated if came from a 4dr to a two door then youll wanna buy stronger shocks to support the door in the up postion(the lil black cylinder) if from a 4dr may wanna get lower psi shocks cause the four doors weight is diff then a two door so they will be two strong.(well unless they are well used shockes lol then may be worked enought where they be ok)
yeah i know that 2dr and 4dr weights are diff. luckly they came from a 2dr and are going on a 2dr. i might put them on tomorrow since its going to be like 60 in ri lol thanks guys.
