I just recently moved back to Maryland from Texas. There is a few things I need help on.
1- Does anybody know a place where I can get an alignment done on my car. The only problem is that I need a place that can do it for a lowered suspension and my with my body kit, my car sits pretty low. So in other words if you know a place where I can clear a very low ramp or like in Texas, have the ramp leveled flat with the floor.
2- My abs light is on but I am pretty sure that my abs is not out. It must be the sensor. Will that pass or do I have to fix it prior to inspection.
3- I have an HID kit installed but it is not a high/low kit. Will they bitch about that or would that pass.
4- Mi fiances car has tint ( I believe) darker than 20%. Will they have to be taken off first or anybody know a place. I can't see in her car in other words
5- My front bumper lip was damaged in an accident. My mesh grille was ripped off and I do not have a bracket on my bumper to install my plates. Will I have to buy a new bumper to pass inspection.
I know it seems like a lot but I just need to really find out asap. My inspection and registration are do soon.
where at in MD? have you had the code for the sensor reset should handle it for the time being, you will have to at least have the plate on when you get it inspected to fab up a way you should be alright, im not to sure about the other stuff tho Good luck
Shayna Wilt wrote:where at in MD? have you had the code for the sensor reset should handle it for the time being, you will have to at least have the plate on when you get it inspected to fab up a way you should be alright, im not to sure about the other stuff tho Good luck
EDIT
cousin stuck his plate in the windshield an it passed
what kinda bumper do you have
