Located in evansville...pickup is welcome.
Up for sale is a zapco 1000 sub amp. this thing is a monster. check out the pics asking 400 shipped. OBO
2 x 250W @ 4 ohms (THD <0.03
2 x 450W @ 2 ohms (THD <0.05
1 x 900W @ 4 ohms bridge (THD <0.05
Fuse: 3 x 30A
Length: 32.5" (82.5cm)
40 bucks shipped. has factory plug included.
General Description
Up to 24dB of Signal Gain
High-headroom PWM Switching Power Supply
13 Volts Peak Output Signal Level
Balanced Differential Inputs and Outputs
2v, 5v, and 7.5volt Output Signal Level Indicator LEDs Capable of Driving
High Capacitance Cable Loads
alpine mrv-t502. looking to get 35 bucks plus shipping.
Power Output at 12V (20Hz ~ 20kHz):
2 x 50W @ 4 ohm (0.08% THD)
2 x 100W @ 2 ohm (0.3% THD)
1 x 200W @ 4 ohm bridged (0.3% THD)
Power Output at 14.4V (20Hz ~ 20kHz):
2 x 75W @ 4 ohm (0.08% THD)
2 x 150W @ 2 ohm (0.3% THD)
1 x 300W @ 4 ohm bridged (0.3% THD)
Freq. Response: 10Hz ~ 50kHz (+0,-1 dB)
S/N Ratio: 100 dBA
Fuse: 30A
Dimensions: 10.6" x 9.4" x 2.1" (27cm x 24cm x 5.3cm)
Weight: 7.3 lb. (3.3 kg.)
Manufactured in 1998-1999
