ok, im in need of everyones help. im looking at doing an auto to manual swap so i need the following parts:
- transmission
- Clutch
- Flywheel
- Manual transmission mounts
- 6 Flywheel to Crank bolts
- 6 Clutch cover to Flywheel bolts w/ lock washers
- Clutch pedal assembly
- Gas/brake pedal assembly
- Clutch master cylinder
- Slave cylinder/throw-out bearing assembly
- Shifter assembly w/ cables
- Axles
- Manual PCM (or reflash)
- Labor
btw, i need 2000-2002 Getrag parts, or if certain parts cross over years thats fine too. but i plan to use the getrag so i need everything that would work with that. please let me know what you have and how much you would like to get for it. or let me know if anyone has any access to anything. i might have left some things out (interior pieces etc
so just clue me in if i did...thanks in advance
I seriously have 90% of that
I have both axles, mounts, shift lever/cables, gas/brake/clutch pedal assembly, clutch master cylinder (and line) and slave cylinder. sorry, no TOB
let me know if you're interested and where you're from so we can arrange a meet-up or shipping
and I know where there's a trans thats low miles and in good shape too
get in touch with me, I'll help ya out
Edited 1 time(s). Last edited Wednesday, October 03, 2007 9:50 PM
