I have a partial air management kit for sale right now.
Includes the following.
(8) 1/2" Blitzluft Valves
7 Switch Chrome AVS Switch box
2 Air Lift dual needle gauges
8 port 5 gallon tank (painted flat black, with aluminum star in center)
2 Port 5 Gallon tank (painted semi gloss black, with flat black stars)
50ft 1/2" Air line
150-175 pressure switch (i think)
The kit is missing the following.
Most of the fittings. The ones they sent me, only 5 out of the 12 I was sent, were the correct ones.
Air Compressor
1/4" Air line (for gauges)
If you're piecing your kit together, this is a great start.
You can go to Easy Streets web site, and pull up a install booklet (PDF) and it'll have all the fittings you need listed there. Then you can go to your favorite source, to order them. (i.e. www.airbagsource.com or www.suicidedoors.com )
I bought the kit from www.fbirides.com (fender bender international), However, the fittings have been on back order for over a month now, and I am tired of waiting, so I canceled the back order, and was refunded the balance. I am only asking $300 which is a little less than I have into it.
Pick up only please.
Also, the valves are pre-wired with 14 gauge wire, and are color coded to make install even easier (black= ground , red= positive) The switch box also comes with a box on the end to connect all your wires too. Will make wiring up valves even more simple. All you'll have to do is extend the wires from the valves, to that box. But I have crimped on Male to Female connectors to clean insure good connections, quick install, and easy un-install have you need to do clean out a valve, or something.
I'll take new pictures of the valves, and switch box tomorrow and post them.
pictures of valves, and chrome switch box. (finger prints included!)
$300 I'm loosing money on this
does it come with the struts/
I listed what comes with it. Its not a complete kit. Just some of the things needed for a air ride set up.
You would need fittings, struts, a compressor, 1/4 inch air line (50 ft) to complete the kit
