For Sale: 1998 Chevrolet Cavalier Z24 5-Speed - Black - Mid East Region Forum
Friday, December 23, 2011 4:48 PM
FOR SALE: Considering offers. Everything included with the car is listed below.
Uploaded with ImageShack.us
My only two major concerns are that the air ride compressor blows fuses sometimes, & may need replaced farther down the road. Not a huge deal.
And the car will NOT come with a hood. I am keeping it. So you will need a hood.
Overall the car is in spectacular condition. Engine has 115,370 original miles, & runs like a top. Does not burn oil. ICE COLD A/C. Transmission, clutch slave cylinder, clutch master cylinder,
SPEC Stage 2 Clutch Kit SC582L w/LIGHTWEIGHT UPGRADE, Prothane Motion Control Front & Rear Transmission Mount Bushings,
Energy Suspension Performance Sway Bar Complete End Link Set and Prothane Motion Control Arm Bushings all have less than 5,000 miles on them.
Leave me a message here if interested or PM me for details. Thanks.
Body Style: Coupe
Color: Black
Engine: 2.4L DOHC
Transmission: Manual
Interior: Cloth/Graphite/Red
Purchase Date: March, 2001
Purchased From: Grand Olds East
Build Date: 1/98
Manufacturer Options
•Cruise Control
•Delay Wipers
•Power Locks
•A31 Power Windows
•Power Mirrors
•C49 Rear Window Electric Fogger (rear defrost)
•Tilt Steering
•Map Lights
•A/C
•AU0 Keyless Entry System
•Power Trunk Release
•Fog Lights
•FE2 Suspension Handling Package
•FX1 Ratio Transaxle Final Drive 3.94
•UH8 Cluster-Cool Temp Tach Trip Odom
•5 speed M.T. Isuzu MJ1
MODIFICATIONS
Engine:
•***PERFORMANCE***
•SECRET CAM Swap ~
•Exhaust Cam & Lifters & Tower from 1990 Pontiac Grand Am 2.3D Motor
•Intake Cam & Lifters from 1995 Pontiac Grand Am 2.3D Motor
•Unorthodox Racing Aluminum Underdrive Crank Pulley (14 oz)
•AC Delco Serpentine Belt
•RKSport Polyurethane Upper Motor Mount Insert
•RKSport Polyurethane Lower Motor Mount
•RKSport Copper-Beryllium Spark Boot Inserts & Isolation Sleeves
•AC Delco Professional Platinum Spark Plugs
•AC Delco Spark Plug Connector Boots
•AEM Polished Short Ram Induction System (22-446P)
•AEM Polished Clutch Fluid Reservoir Bracket (20-445)
•APC Compact Red/Chrome Air Filter 151411 (5/31/08)
•Removed Tuner Tube
•Removed Intake Resonator
•Borla 2 1/4 inch T-304 Stainless Steel Turbo Muffler (40652)
•Chrome Muffler Tip
•Optima Red Top Battery 75/25 910 CA/720 CCA(4/04/08)
•Prothane Motion Control Front Transmission Mount Bushing 7-514 (4/29/08)
•Prothane Motion Control Rear Transmission Mount Bushing 7-515 (4/29/08)
•Midwest Remanufactured 5SPD Transmission
•ACDelco Clutch Master Cylinder 18M2223
•SPEC Stage 2 Clutch Kit SC582L w/LIGHTWEIGHT UPGRADE (4/29/08)
•Brand New AC Delco A/C Compressor . Accumulator . Orfice Tube . Pag Oil (7/17/08)
•***DRESS/APPEARANCE***
•Black QUAD 4 H.O. IDI CAM Cover
•Polished Fuel Rail (5/31/08)
•G SLEEVE Hose & Cable Sleeving Kit (Carbon)
•Black Wire Looms
•Battery Tender Junior
Suspension/Wheels/Brakes:
•GM Performance Parts Strut Tower Brace (Powdercoated Red) GM# 22604347
•Energy Suspension Performance Sway Bar Complete End Link Set (Front)# 9.8120R (4/29/08)
•Prothane Motion Control Arm Bushings (4/29/08)
•Front End Alignment (5/26/08)
•EasyStreet Air Ride Suspension
•2 Front 9-way Dampening Air Struts
•2 Rear 9-way Dampening Air Struts
•1/2" Air Lines
•(8) 3/8" Electronic Chrome 300 PSI Valves
•Viair Chrome 380C Compressor
•5 Gallon D.O.T. Approved Air Tank with 8 1/2" Ports
•145-175 PSI Pressure Switch
•APP Black Smoked 10 Switch Box
•4 SMC Adjustable Fill Controls (1/2" PTC) (7/4/08)
•4 SMC Adjustable Dump Controls (3/8" thread) (7/4/08)
•Sport Max Racing "008" 18x7.5 Black/Polished Rims Offset: +42mm
•Kelly Fierce HP High-Performance Directional Radials P225/40/ZR18
•Motegi Black Spline Drive Wheel Locks
•Ichibahn Polished Valve Stem Caps
•SR Drilled Performance Rotors
•Bendix CT3 Ceramic Brake Pads
•Black Painted Calipers
•Black Painted Drums
Interior:
•APC F1 Red & Black Racing Seats (no logos)
•Custom Racing Seat Brackets
•Shortened Shifter 3 Inches
•NIKEN Red Carbon Fiber Kevlar Shifter Knob
•APC Black Leather Shifter Boot with Red Stitching
•A+ Performance Red Leather E-Brake Boot
•Ichibahn Red Hole Series Manual Pedals
•Misc. Interior Trim Painted Torch Red
•Console Cover Re-apholstered with Red Cloth
•Red Headliner
•Polarg M6 Xenon Super White Dome Light Bulb (C912)
•Carbon Fiber Speedometer Gauge Bezel (Alfa Otto)
•Black Cat Custom One-off "XTREMZ24" White/Red Face Gauges
•Black Cat Custom White/Red HVAC Panel
•Black Cat Custom White/Red Fog lamp/dimmer panel
•4 Red Speedometer Gauge Cluster LED's (#WLED-RHP6) (6/21/08)
•4 DORMAN 1/2" Instrument Panel Sockets (#85835) (6/21/08)
•2 Red HVAC LED's (#74-RHP) (6/21/08)
•Street Glow Neon Interior Lighting Under Dash (Red)
•Street Glow 20" Red Neon Rod in Trunk
•Street Glow Red Hott Wirez neon wire on Both Interior Doors
•Auto Custom Carpets Torch Red Carpet
•New Factory Graphite Floor Mats
•PROPARTS Full Pillar Dual Gauge Pod # 92095
•EasyStreet Dual Needle Lighted Air Pressure Gauges
•Red PSI Gauge LED's (#194) (6/18/08)
Exterior:
HOOD NOT INCLUDED. NO HOOD YOU WILL NEED TO PROVIDE YOUR OWN.
•Ground Designs Full Fiberglass Drift Body Kit
•Black One Piece Halo Projector Headlights (7/8/08)
•Amber 5-LED bulbs in the corners (WLED-A5)
•Black Freshly Painted Power Mirrors
•Real Carbon Fiber Gas Door
•Sonar Carbon Fiber Outter Tail Lights
•APC Carbon Fiber Inner Tail Lights
•Limo Tinted Windows (back 3 windows only)
•Shaved Badges
•Shaved Side Moldings
•Liteglow Red LED Underbody Neon Kit w/10 Patterns
•Front & Rear White Bumper Mesh For The Drift Kit
•Farenheit Super White Xenon Charged Blue Bulbs (H1)
•Farenheit Super White Xenon Charged Blue Bulbs (9005)
•Venom Custom Fiberglass Spoiler
•Custom Made Carbon Fiber "XTREM" Decal on trunk lid
•TRICO NEOFORM BEAM BLADE Wiper Blades (D 16-170 P 16-220)
•New Horn (6/17/08)
Audio:
•Pioneer DEH-P7600MP CD Receiver (MP3/WMA Compatable)
•Front - Pioneer TSA1680R 220WATT 4-Way 6.5" Speakers
•6.5" Front Speaker Adapters
•Dynamat Xtreme Speaker Kit - 10415
•Rear - Pioneer TSA6990R 400W 5-way 6x9 Speakers
Miscellaneous:
•Shows Attended:
•4th Annual J-BODY BASH August 10 11 12 2001 Lordstown OH
•GM UAW 2nd Annual Make A Wish CAR & BIKE SHOW August 11 2001
•5th Annual J-BODY BASH July 26 27 28 2002 Austinburg OH
•EMPIRE MOTORSPORTS AUTO & BIKE SHOW - June 28 & 29 2003 Kalamazoo MI
•6th Annual J-BODY BASH July 31-August 2 2003 St. Louis MO
•1st Annual Cole Motor Mall Car Show - June 19 2004 Portage MI
•7th Annual J-BODY BASH August 6-7 2004 Lordstown OH
•1st Annual GMSC BASH - July 8th & 9th 2005 Indianapolis IN
•KUHMO STREET WARRIORZ SERIES USACI SOUNDOFF & CAR SHOW - July 16th 2005 Martin MI
•V6Z24 Bash 2005 - July 22 23 24 2005 Kalamazoo MI
•Desired Image 4th Annual Car Show - June 9th 2007 Flint MI
•1st Annual 2007 GM Tuner Bash - July 26 27 28 29 2007 Mansfield OH
•Desired Image 5th Annual Car Show - June 7th 2008 Flint MI
•2nd Annual 2008 GM Tuner Bash - July 25 26 27 2008 Xenia OH
•Deano's Pizza & Ice Cream 8th Annual Car Show August 10th 2008 Allegan MI
•3rd Annual 2009 GM Tuner Bash - June 18 19 20 2009 Harrison OH
•Deano's Pizza & Ice Cream 9th Annual Car Show August 9th 2009 Allegan MI
•Import Face Off - June 6 2010 - Martin MI
•Awards / Media:
•EMPIRE MOTORSPORTS AUTO & BIKE SHOW - June 28 & 29 2003- New Performance - 1st Place Best Of Show -
•Appeared in StreetSource Magazine 2003
•Featured in J-BODY Magazine 2nd Quarter 2004 Issue#2 (4 page spread)
•Appeared in Gauge Magazine November 2004
•1st Annual GMSC BASH - July 8th & 9th 2005 - 95-99 Cavalier Street - 3rd Place
•Appeared in MiniStyle Magazine ~ 2005 GMSC Bash - Indianapolis IN
•KUHMO STREET WARRIORZ SERIES USACI SOUNDOFF & CAR SHOW - July 16th 2005 - Sport Compact - Domestic Mild - 1st Place
•V6Z24 Bash 2005 - July 22 23 24 2005 - 1st Place J-BODY
•Appeared in Gauge Magazine September 2005
•Desired Image 4th Annual Car Show - June 9th 2007 - Domestic Sport Compact Mild - 2nd Place
•2008 JBodySource Calendar - Cover & October Featured Ride
•Desired Image 5th Annual Car Show - June 7th 2008 - J-Body Mild - 1st Place
•2nd Annual 2008 GM Tuner Bash - July 25 26 27 2008 - J-body Wild - 2nd Place
•Deano's Pizza & Ice Cream 8th Annual Car Show - August 10th 2008 - Tuner Car/Sport Compact 1st Place
•Appeared in Gauge Magazine January 2009
•3rd Annual 2009 GM Tuner Bash - June 18 19 20 2009 - J-body Wild 3rd Place
•Deano's Pizza & Ice Cream 9th Annual Car Show - August 9th 2009 - Tuner Car/Sport Compact 1st Place
•Import Face Off - June 6 2010 - Martin MI - Sport Compact Domestic 2nd Place
Edited 2 time(s). Last edited Friday, December 23, 2011 5:14 PM
Supercharged 2002 Cavalier Z24
J-Body / GM TUNER Bash Veteran
Re: For Sale: 1998 Chevrolet Cavalier Z24 5-Speed - Black
Saturday, December 24, 2011 8:16 AM
sorry to hear man. glws
Monday, December 26, 2011 6:27 AM
Hope this goes to a good home
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
Tuesday, December 27, 2011 8:26 PM
Me too. It has been babied. Anything it has ever needed has gotten replaced.
I just don't have time for it, drove it once this year, 3 times last year.
Sunday, January 01, 2012 8:51 AM
sorry to see man. good luck man
Tuesday, January 03, 2012 12:18 PM
-MD- Enforcer wrote:sorry to see man. good luck man
Sunday, January 08, 2012 8:11 PM
Sale pending....
Saturday, January 14, 2012 9:48 AM
Sold
Saturday, January 14, 2012 10:05 AM
Congrats man. Hopefully to just as good a home as she came from.
Monday, January 16, 2012 10:12 PM
The guy has a heated garage to store it in. I think he will take very good care of it.
Monday, January 16, 2012 10:53 PM
Not sure what you were asking, but hope you got enough for it... Congrats on sale.
Monday, January 16, 2012 11:07 PM
I think I got pretty good value for it & what I had invested in it. Over time I understand depreciation as far as the $19,000 I had invested in it.
Didn't get anything near that, but way more than a stock KBB value.
I think of it as fun money, I spent it while having a good time, always knowing I would never get it back...
I still have this Blue 2k2 Z24 to play with, so I'm not out of the game yet.
Just taking a little break I guess.
Tuesday, January 17, 2012 1:18 AM
Good to hear. Thought about doing the same for mine in a year or two, or keeping it and being a lifer.
Tuesday, January 17, 2012 9:30 AM
Vince and I will soon be the last remaining J owners on this site. Lol.
congrats on the quick sale Kevin!
BeardLife / Club Awesome Reject Blog
Tuesday, January 17, 2012 10:35 AM
I think i will Jay lol
Tuesday, January 17, 2012 11:36 AM
glad it went to a good home. it sucks to have to watch it go though....that was your baby for years.
