Like the title says, if its not already installed its for sale.... I may be forgetting some stuff so feel free to ask but that means IF ITS ON THE CAR ITS NOT FOR SALE.
-Slightly used Hahn Racecraft Ecotec Stage 2 Turbo Kit, originally it was on one of GM's show cars, it was removed before the car went to get crushed. I got it from there and it was installed for about 5 miles on my silver cav then removed and has been sitting since. It's the full stage 2 kit but does not come with the FMU or fuel pump. It does come with some upgrades, the charge pipes you see from the engine bay are powder coated metallic silver along with that box for the TB (couple hundred dollars), I also have brand new never used replacement pipes for the box, Hahn stopped using the box cause it always had problems leaking and started using pipes (about $120). The turbo manifold is coated in JetHot2000 coating (about $250) $2500 for it all, will not ship
-Ecotec L61 motor - about 5000-6000 miles on it out of a Sunfire, flywheel, intake manifold, throttle body, etc, no cams or valve cover, very mild porting on the exhaust side of the head. Perfect candidate for a build. $? will not ship
-Ecotec L61 Eagle forged crankshaft WITH timing ring, rare and discontinued (BRAND NEW) $500 pick up preferred
-Ecotec L61 Eagle forged H beam connecting rods (BRAND NEW) $350
-Ecotec L61 Wiseco Forged 10:1 stock bore pistons with rings and wrist pins (BRAND NEW) $450
-Ecotec L61 ARP head studs (BRAND NEW) $130
-Ecotec L61GM Racing neutral balance shafts (BRAND NEW) $350
-Ecotec L61 GM Racing hardened oil pump gears (BRAND NEW) $350
-Ecotec L61 GM Racing FULL valve train.... stainless steel .5 mm over sized intake valves, inconel .5 mm oversized exhaust valves, single groove valve Keepers, chrome silicon vanadium steel alloy dual valve springs, titanium alloy retainers, and spring seats (BRAND NEW) $1000
-Lotek 03+ cavi triple gauge pod A-Pillar (BRAND NEW) $50
-Autometer Phantom Series boost gauge (BRAND NEW) $50
-Autometer Phantom Series oil pressure gauge (BRAND NEW) $50
-Autometer Phantom Series fuel pressure gauge (BRAND NEW) $50
-Autometer Phantom Series EGT Gauge (BRAND NEW) $125
-Inovate LM-1 Wideband (BRAND NEW) $350 (I may keep this, install it, tune my car N/A then sell it as one time used)
-Inovate wideband 02 bung (BRAND NEW) $10
-Alpine V12 1000 watt mono amp (puts out 1111 watts rms at 2 ohms according to Alpine's birth sheet) $300 will not ship
-Alpine Type R 12" subwoofers (2) in a new sealed box (subs are wired to a 2 ohm load, perfect match for the amp listed above) $200 will not ship
-Alpine V12 500 watt RMS mono amp (same thing as the first amp just 1/2 the size and half the power, the little screws for the end plate are missing, I lost them a LONG time ago) $120
-Alpine Type R 12" subwoofer, no box, dual 4 ohm (can be wired to a 2 ohm load to match perfectly with above amp) $65 will not ship
-Alpine IVA-D300 in dash screen. Its a motorized flip out touchscreen, MP3, CD, WMA, DVD, etc.. am/fm, 3 sets of RCA outputs, RCA video outputs, RCA aux. input. lots of features, has a light sensor and is auto dimming, you can set it up to open when the car is started, close when the car turns off, only open and close if you hit the button, close when you shut the car off but not open unless you hit the button, etc. you put a sound delay on each individual speaker to center the sound around a specific seating position, you can adjust the normal audio controls, you can control the sub level, you can adjust the crossover settings, lots and lots of stuff. Some extras, wireless remote, door chime module, swith to wire into parking brake wire and ground to bypass the safety (so you can watch movies or whatever while driving, not just when the parking brake is on). Cable that plugs into the aux RCAs and goes to a headphones jack, plug in any ipod, mp3 player, even cell phone and play the music through the stereo. Very very nice unit, puts out very clean sound, very amp friendly, this is not the cheap Jensen flip out bull@!#$. $600
-Spal Shaved door kit, brand new still in the wrapping, never opened. $100
-Billet grill for 03+ cav $40
