I'm needing the 99 tables copied over to my 97 pcm if possible so I don't have to switch knock sensors. Though can if needed. Would rather not though. I need the egr codes turned off and the rear o2 sensor also.
I don't have a wideband in the car anymore but would like to get tighten up the factory junk program. Little background on the car is. 99 sunfire with a 2000 2.4 5 speed swap. Running a 97 computer and harness. HO intake, 2.3 tb, 4-1 header with 2.5 all the way back with no cat. Preferably someone close to 26836 which is the eastern panhandle of wv.
Will pay that isn't a problem. Thanks for any help.
No one going to tune your car without a wideband....
lol I just sold it as it was in the ta. I wasn't really looking for a tune... Tune... Just need the tune cleared up to get rid of the annoying idiot lights. Egr and no rear o2. Possibly the 99 timing table copied over if they are different. That or just the whole 99 flash flashed to the pcm then just turn the rear o2 off.
I could even pull the pcm and ship it to some one to plug it into there harness to flash it. I how ever know the pcm can still be tuned with no wideband. Can't really go to far or depend on the readings wide open to a point. But that is how the ta was tuned and many others. I how ever see the point also.
