i have a 1996 cavalier z24 2.4 twin cam auto im looking for all the parts to swap to a manual. flywheel, clutch, trans, mounts, shift cables, shifter, boot, console, clutch master cyl, slave cyl, pedal assembly, hydraulic line, clutch fluid resevoir, you get the idea. i want EVERYTHING needed to swap. im looking to pay around $150. if you got what i need, hit me up.
Id say your best bet is to hit a junk yard in your area. Should be able to get most of the stuff you need fairly cheap.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
i dont really have all the surplus time to go to a junkyard, the closest pick and pull is on the southside of columbus and im just north of columbus. thats why i figured id ask here.
