The engine has about 6k miles on it. It has Wiseco 10:1 pistons, eagle rods, new GM rod bearings, lzm balance shaft delete kit, patriot ported head, lsj valves, supertech valvetrain, stock cams, and I'll throw in the spec stage 3 clutch as well. It had the oil filter housing drilled and tapped for an oil feed and the thermostat housing is drilled and tapped for a coolant feed.
Pick up only.
I'm asking 1500 plus a running motor in decent condition or 2000 without one.
I would also let the entire car go for 4500 (motor included). It is a 2003 red base model coupe. It has 104,000 miles in the body and is lowered on Stechs on stock struts. It definitely needs new paint and some work on the bumpers, but everything else is in good condition. I will post up pictures tonight when I get home.
What did you get now? Or buying next?
![](http://www.crawfordz.com/adam/rob/sig.jpg)
2004 Cavalier. Razzi. (Sold)
1998 Corvette. Some mods.
1992 Typhoon. Lots of mods.
1994 Civic VX 44MPG
