Jmts full turbo kit 1200
-ITS street heat series 57 turbo no shaft play
-griffin FMIC
-ITS Mini-me wastegate
-powdercoated candy blue charge pipes
-jmts equal length manifold
-MSD inline booster pump with all lines and mounting bracket for shock tower mount
-couplers and everything just no tbolt clamps
-hks ssqv bov flange I have no clue whee the bov went to
full Eco shell minus motor if you need any parts let me know
95-99 z wheels need tires 150
also looking to buy
suspension or any kind
Eco motor mounts
Eco exhaust
or any other eco stuff
willing to trade the turbo kit for a Saab kit or a gm sc kit
I sold the black car and just couldn't stay away so now just got another one
http://i15.photobucket.com/albums/a381/maxxracer23/ModdinArtSignature.gif[/IMG]
Auto ecotec engine harness? Possibly with ABS?
Either way, I could use it. Thanks!
maybe Higgins or Robert can shine some light of this, but here's the deal.. i'm doing an Eco swap into my 'o1 Z24. my car has ABS but the donor car doesn't, so I have the ABS brake master and control module, but non-ABS wiring, PCM, and axles. now, if ABS isn't controlled by the PCM in any way, i'll keep my ABS module and go get some ABS axles.. and would want your ABS 5spd harness.. if you have one. you can look for the control module plug to make sure whether it has ABS or not.. the plug is hard to miss
![](http://i316.photobucket.com/albums/mm332/synthetikxnapalm/Signatures/pearl.jpg)
R.I.P. JessE Gerard 7.11.87 - 1.25.08
The Radiation Nation Facebook Twitter Twisted Metal Alliance
You can just use your 01 Z24 axles evan, thats what im doing. I had the same problem. Actually my motor came out of a saturn ION. So i have a lot of stuff i need to swap over. But all you should need is an ABS harness and you should be good. Since your 01 Z24 already has ABS. And ABS is controlled by the BCM, which you shouldnt have to change.
could you send me some pictures of the turbo kit?
If u can find an eco block n get it all rdy for a engine swap in my 02, I'll buy it.. I have cash in hand...can text me at 812 207 5394 if u want to get this together
pics of the turbo kit por favor
would you sell just the manifold? or trade for my log str with some cash?
running rich? turn the boost up
hey i will buy it, I would like to meet up so i can look at it all.
