Well, now that the Cavalier is gone I was cleaning out the garage of all my old project stuff. I figured someone might want some of this stuff to save some money and if I can get a few bucks more in the end, it's a win-win situation. So, if you're interested in any of this stuff, make a best offer.
Here are the rules:
- Whatever doesn't get sold is going in the trash, no turning back, so don't wait and expect the unsold stuff to still be here next week.
- I accept Paypal only, and add $1 to your offer for Paypal fees.
- Everything is going by USPS Priority Mail flat rate box because I don't want to deal with the hassle of buying boxes, calculating shipping cost by weight, etc etc. I'll try to throw it in the smallest one possible depending on what/how much you buy. In case you don't know, sizes cost $4.95, $10.70, and $14.50 for USA.
- Everything is getting Delivery Confirmation, so add $0.80 to your offer.
- I'm headed to the post office on Friday morning 4/23 to ship everything at once. That means I need your money in my Paypal account by Thursday 10PM (ET) 4/22.
- When making your offer, please consider that you have to make it worth my while to drive and spend my time in line at the post office. If you say $1, it's easier for me to throw your item in the trash and go about the rest of my day.
1) Needle nose pliers, channel lock pliers, collapsible lug wrench, Companion set of 1/4" and 3/8" metric and standard sockets with ratchets, screwdriver handle and bits.
2) Scantool.net scantool. This is an older scantool that uses their free software from their website. It's somewhat limited, but will show you map, tps, iat, O2 voltage, rpm, closed/open loop, clear the CEL, and a few other small things. RS232 to USB adapter included. Only works with similar generation GM vehicles.
3) Washer fluid tank. This doesn't fit in a USPS PM FRB, so shipping cost will be higher and will vary.
4) K&N filter recharge kit (99-5000). Oil and cleaner should still be good, 50-75% left. Intake hose clamps as well.
5) OEM clear light bulbs in random packaging. (4) 194, (1) 912, (2) 880.
6) 3M automotive attachment tape (1/2") 06382. About 40% left.
7) (11) Stock 12x1.5 wheel studs.
8) 1/8" copper crush stop sleeves that I used when modifying (cutting) my stock ebrake cable for my daytona swap. About (30) left.
9) Random audio wiring.
- Alarm hood pin
- 4ga fuse holder with 100 amp glass fuse
- Wireloom, (3) 4" tubes
- (2) fuse holders (30 amp max)
- Felt battery post washers
- Rockford Fosgate amp wire terminal set screws
- 18ga speaker wire - 5ft
- 4ga wire - red - 16", 32", 32"
- 4ga wire - black - 14"
- 8ga wire - red - 25", 44", 46"
- 8ga wire - black - 18", 25"
- (4) 4ga ring terminals
- (1) 8ga ring terminal
- (2) 8ga fork terminals
10) Interior vinyl
- Graphite - 30"x54". Matches stock graphite dash, used it to cover up the dash crack. Not sure if remaining vinyl will be enough to cover another crack, but should cover other small pieces.
- Dove grey (Katzkin match) - 32x54".
- 3M rubber & vinyl spray glue #80 - about 90% left, it's practically brand new; just bought it 2 weeks ago for another small project.
PM me if you want something . . .
