Audiobahn System FOR SALE - South East Region Forum
Thursday, October 04, 2007 10:32 PM
I'm selling the system out of my car for $650. If you are interested or have any questions, please let me know. All the specs are listed for the subs, amp, and head unit.
2 12" Audiobahn AW1208T Flame-Q subs with metal paintable flamed grill covers in custom built box.
1 Audiobahn A2150HCT High Current Flame-Q 2-Channel Amp with Remote Mount Bass Boost Control
1 Pioneer DEH-P6600 Head Unit with detachable face and remote control
SPECS:
Audiobahn AW1208T Subs
Features
* Optimized for Maximum SPL Ported Enclosures
* PHAT 2” Multi-layer Foam Surround
* 280 oz. Magnet
* Stamped and Balanced Aluminum Cone
* 6 mm Thick Cast Flame Basket
* Multi-Connect Lug-Lock Terminals
* Mounting Depth: 6 3/4”
* Hole Cutout: 10 7/8”
* Outer Diameter: 12 1/2”
Subwoofer Specifications
* Size: 12"
* Rec. Sealed Box Dims: Not Recommended
* Rec. Ported Box Dims: 1.30 - 3.15 cu. ft.
* Free Air Usage: Not Recommended
* Sensitivity: 91 dB
* Frequency Response: 20-500 Hz
* Recommended RMS Power: 1500W
* Peak Power Handling: 3000W
* Impedance: Dual 2 Ohms
Audiobahn A2150HCT Amp
Features
* High Current Circuitry
* 1-Ohm Stable: 1200W Into A 1-Ohm Load
* PWM MOSFET Power Supply
* Double-Sided Glass Epoxy Circuit Board
* Variable Parametric Bass Boost
* Remote Bass Control with Blue Backlight Knob
* Variable 24 dB High & Low-Pass Crossovers
* Variable Subsonic Filter (20-45 Hz)
* 4-Way Protection Circuitry
* Cobalt Blue Illumination
* Blue LED Voltage and Status LEDs
* VU Meters Indicating Output Response
* Secondary Flame-Style Heat Sink
* High Gloss Chrome-Plated Finish
* Nickel-Plated Block Terminals
* Dual Fan Cooled
2-Channel Amp Specifications
* Amplifier Type: 2-Channel
* RMS Power @ 4 Ohms: 150W x 2
* THD at 4-Ohm RMS Power: 0.05%
* Bridged RMS Power @ 4 Ohms: 300W x 1
* Speaker Level Inputs: No
* Preamp Outputs: Yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 10-20,000 Hz
* Signal to Noise Ratio: >100 dB
* Supertuner IIID (AM/FM Radio)
* 24-Station/6-Button (18FM/6AM) Presets
* BSM (Best Stations Memory)
* 1-bit D/A Converter: 16-bit
* CD-R/CD-RW Compatible
* AGC (Automatic Gain Control)
* Disc Title Memory
* CD Text
* Additional System Expandability
* IP-Bus System Control
* Multi-CD Control
* DVD Control
* TV Tuner Control
* Built-in Auxiliary Input: CD-RB10 or CD-RB20 required
* External Unit Control: 2
* Display Type: Organic EL (OEL)
* Dot Matrix OEL Size: 128x32 + 24x32 (Blue + White)
* Screensaver Movies: 2 (Air Show, Lost Shipwreck)
* Background Animations: 4
* Level Indicators: 2
* Built-in Speaker Power: MOSFET 50W x 4
* Equalizer: EEQ (3-Band Parametric)
* Equalizer Presets: 5
* User Equalizer Settings: 2
* Sound Focus EQ
* EQ-EX
* Loudness: 3 Mode
* Electronic Balance/Fader
* Source Level Adjuster (SLA)
* Crossover Network: Two-Way Crossover
* High-Pass Crossover (HPF): 50/80/125Hz, -12dB/Oct.
* Subwoofer Crossover (LPF): 50/80/125Hz, -18dB/Oct., +/-12dB
* RCA Preouts: 3 pair (Front, Rear, Sub/Non-Fading)
* Preout Voltage & Impedance: 2V, 100 Ohm
* Remote Control: Card
* Wired Remote Input
* Cellular Mute
* Detachable Face Security
* Face Case (Included)
Re: Audiobahn System FOR SALE
Saturday, October 06, 2007 3:05 AM
i didn't even try reading all that's involved in that!
good luck with sale
consider this a free bump
http://www.myspace.com/fpsunfire
5 seconds to find another street...
Tuesday, October 23, 2007 9:02 PM
bump again
Tuesday, October 23, 2007 9:11 PM
BUMP for a really good system. that DEHP6600 deck has GREAT built in X-Overs... they will make your full range speakers sound infinitely better.
Orlando, FL
"An okay movie is the same as an ex girlfriend...it was good at the time,
but you never want to see it again... especially if the movie was a bitch."
Monday, October 29, 2007 4:23 PM
radio is sold now for the amp and subs??? any takers?
