Selling all of my car Audio - Canadian Mid East Region Forum
Tuesday, July 22, 2008 10:59 AM
I'm selling all of my cars audio, I need this stuff gone.
-PIONEER GM-7200M - 800 WATT MAX MONO Pioneer Amplifier
Product Features:
LPF 40 – 2KOHz (12DB /OCTAVE)
BASS BOOST 50Hz (0 / 6 / 12dB)
SPEAKER LEVEL INPUT
2 OHM MONO STABLE
CAST ALUMINUM HEATSINK
OVERSIZED POWER TERMINALS
INPUT LEVEL (200Mv-6.5Mv)
POWER RATINGS
800 WATTS MAXIMUM OUTPUT X 1 @ 2 OHMS
250 WATTS X 1 (4 OHM) OR 500 WATTS MAX
360 WATTS X 1 (2 OHM)
-PIONEER TSW126DVC Premier 12" Component Subwoofer
Product Features:
Size 12"
Woofer Cone Material Interlaced Carbon Fiber Reinforced IMPP Cone Woofer
Surround Wide-Roll 3-Layer Fiber Woven Radial with Honeycomb Cloth
Overhung Surround Design
Voice Coil High Inductance, Dual 4-Layer, Long Voice Coil
Ceramic-Coated Voice Coil Wire
Voice Coil Bobbin Slit Aluminum Coil Bobbin
Conex Damper with Damper Ring
Top Plate Thick 7/8" (23mm)
Projected Pole Yoke with Vented Pole
Aero-Dynamic Magnetic Gap Design
Magnet Construction Massive Triple Stacked (83 oz.)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket (None)
Wire Terminals Compression Binding Posts Wire Terminal
Specifications
Watts MAX. Music Power 1000W
Watts Nominal Power Handling 400W
Frequency Response 18Hz ~ 2kHz
Sensitivity 89dB
Ohm Rating DVC (2ohm or 8ohm) SVC 4ohm
Recommended Enclosure 1.5 Cubic Feet
-Ported Bassworx Box
Everything listed in in excellent working condition.
I would like to sell the above as a kit with all the necessary wiring and fuses.
$250
-JVC KD-AVX2 CD/MP3/DVD-VIDEO/DVD-AUDIO
Great shape
$220
Product Features:
Power Output:20W x 4 (RMS) 50W x 4 Max.
MOS-FET Power Amp
Built-in 3.5-Inch Wide Monitor
GIGA MP3 Multi
7-Band iEQ
Ready for iPod* In Conjunction with KS-PD100
SAT Radio Ready
MP3/WMA DVD-Audio WAV CD/CD-R/CD-RW Compatible with ID3/WMA Tag
JPEG Playback
DVD-R/-RW,+R/+RW,VCD Multi-Border DVD Compatible
5.1 Channel DTS/Dolby Digital/Dolby Pro Logic II/ MPEG Audio
Time Alignment (5.1ch)
Gold-Plated Line Output Terminals (2 Pairs)
Gold-Plated Center Channel Output Terminal
Gold-Plated Video Output Terminals
Second Gold-Plated Audio Output Terminals
Gold-Plated Subwoofer Output Terminals with Level/Frequency Control
Gold-Plated AV Input Terminals
Motorized Slide-Out Faceplate
Dual-Zone Function with Headphone Surround
Shock Proof Memory
WallPaper Setting
BRAND NEW, NEVER OPENED
6-1/2" (and 6-3/4" locations) Reference Series 2-way Car Speakers
These can fit in your sunfires, cavaliers with slight modification,
$60
Product Features:
Power Handling:
Peak: 180 watts
RMS: 60 watts
Injection molded polypropylene woofer
Plus One woofer cones - This patent pending technology deliver a cone with more surface area than competing models of the same size. The result is increased bass output and higher efficiency
1-3/4" Edge-driven textile dome tweeters
Unipivot allows the tweeter to be pointed at the listeners location even when the speaker is mounted off axis. This optimizes the stereo image and ensures a more uniform response
Tweeter level adjustment (0 dB, 3 dB)
4 ohms impedance
Top-mount depth: 1-15/16"
1-year Sonic Electronix warranty
and
Used ALPINE SPS-6936 100 Watts
$20
Product features:
Active / Passive Speakers: Passive
Active/passive: Passive
Built In/External: Built-in Passive
Category: Pair of Speakers
Custom Fit: No
Direction (1-4 Way): 3 way
Installation: Built-In
Installation Type: Built-In
Number of Ways: 3
Oval Size In mm: 155 X 225
Oval size (mm): 160 X 230
Power (Watts): 30 Watts Peak, 100 Watts Max.
Size (Diameter) in mm: 403
Speakers Format: Oval
System/Single Speaker: Single Speaker
Type of Set: Pair
Wattage: 100
Ways: 3
Year of Introduction: 1997
1/4 Mile ET 15.2579 at 89.97mph
Re: Selling all of my car Audio
Saturday, July 26, 2008 9:11 AM
Subwoofer setup is sold.
looking to get rid of the rest of my audio, make some offers guys.
Saturday, August 23, 2008 2:55 PM
hey is the pioneer amp gone?
Saturday, August 23, 2008 10:14 PM
where are you located?
Sunday, August 24, 2008 9:51 AM
Hey the pioneer amp is gone, I'm located near clinton ontario, in vanastra. The only thing left is the infinity speakers.
