I have a bunch of Eco parts that i was going to use to turbo the car but I got a really great opertunity to buy a Nissan 240sx, So i need the stuff gone to help fund that project.
BRAND NEW STILL IN SEALED BOX:
Timing Cover Gasket- $25
Rear Main Seal- $3
Valve Cover Gasket- $25
Exhaust Manifold Gasket- $15
Water pump Gaskets ( mounting, cover, and outlet)- $20
Knock Sensor- $25
Oil Pressure Sensor- $15
Air Charge Temp Semsor- $15
Coolent Temp Sensor- $10
Crank Positioning Sensor- $20
Balance Shaft timing kit- $110
Cam Timing kit- $140
I also have:
Ecotec Block- $ 50
Head ( needs one Lash adjuster)- $50
Oil Pan - $10
Valve Cover - $30 ( will be able to sell after May 21)
Timing Cover- $20
(2) stock Exhaust Manifold- $5 each
Intake Manifold- $20
All Water pump tubes from pump to the mass around the thermastate- $10
I also have a set of Graphit Door panels that have the holes for Manual Windows. Alittle beat up but a new fiberglass project. Free as long as you come and pick them up.
i'll take ur valve cover!
________________
WI-Jtuners member
