ok so i got a short trow from a guy on here and the install info didn't come with it so i need to get them so i can intall it be4 this weekend please and thank you
explain to me what a short trow is... do you mean a short throw shifter???if you do, and its a b&m, the instructions can be had off of their website...the ld9 and l61 shifters are the same so unless you have an Ln2 this should work.
i am in a good mood, so i will even give u the link...
Short Throw Install Instructions
EDIT: after reading your profile I see you have the ln2....these instructions should still help you a bit.
Edited 1 time(s). Last edited Tuesday, April 21, 2009 4:00 PM
well i belive i have the ln2 its the 1996 2.2 well it still work??? and that just shows you what the shifter is and does sorry man but thanks
sorry man i didn't see the adobe thing thanks again man
and make sure you mark the shift cables to get them in the same spot too
95-99 is one style shifter 00-05 is another. doesnt matter motor. search the transmission forum, there are instructions with pictures and everything, a nice write up.
Vincent Morris wrote:and make sure you mark the shift cables to get them in the same spot too
Very important. I forgot to do this and I put my fore-aft shift cable in way too deep. I could still get into every gear, but when I shifted aggressively I would tear out the cable and have to pull over and fix it. I ended up letting it sit where I tore it out last time and moved it up a little bit.
At this point I'm assuming it's in the right spot, I can hit every gear perfectly and I haven't torn it out again so.. Whatever...
Basically, mark the @!#$ shift cables
Visit Fusion 9 Design for all your web design needs.
Bumper Killer (Ron Carvalho) wrote:Vincent Morris wrote:and make sure you mark the shift cables to get them in the same spot too
yes for sure i well do this!!!
ok so i got the shifter in and works good except for 2nd gear it seems that its not all the way aka "there" like then your wot and try to hit 2nd hard you miss it.
it is as if the shifter isn't going back far enough to let the cable shift in the gear. so i did my first test run and found this prob out so i moved it up a little and its more "there" now but i think is could use more but thats as far forward as the shifter goes so what do i do????
i think im in the same boat i believe...
Vincent Morris wrote:i think im in the same boat i believe...
ya i think i'ma have to do it soon!! cause i hate not being able to slam 2nd
