Engine
•Eagle connecting rods-NOT UNTIL MOTOR IS PULLED
•Wiseco 8.9:1 compression pistons-NOT UNTIL MOTOR IS PULLED
•Level Zero Motorsports balance shaft delete kit-NO
•Cometic 87mm .030 thickness head gasket-NO
•Patriot Stage 2 head with 1mm oversized valves-YES
•RK Sport under-driven and lightweight crank pulley-NO
•AEM over-driven and lightweight alternator pulley-NO
•Custom bored straight-thru 62mm throttle body-NO
•Prothane polyurethane lower motor mount-YES
•RK Sport upper motor mount-YES
•Prothane Polyurethane transmission mounts-IF I CAN MAKE TRUE SOLID MOUNTS
•Hahn Racecraft turbo kit-ALREADY HACKED UP BUT PIECES ARE FOR SALE
•Super 20G turbo upgrade-NOT UNTIL I GET MY GT35R
•Tial 50mm blow off valve-NO
•3 inch custom made exhaust with a FlowMaster 40 series muffler-PIPING IS, MUFFLER AIN'T
•SPEC stage 3+ clutch-MAYBE
•Innovate LM1 RPM wideband kit-NO
•HP Tuners ECU tuning software-YES
•MSD DIS2 HO ignition box conversion-YES
•MSD Blaster coils-YES
•MSD 8.5mm Super Conductor spark plug wires-YES
•Champion copper SRT4 spark plugs-NO
•Team Green LSD Insert-NO
•ARP headstuds-NO
•Front mount intercooler upgraded-NO
Suspension/Wheels/Brakes
•Custom made swaybar endlinks with Prothane polyurethane bushings-NO BUT I'LL MAKE YOU SOME
•Front and Rear Freedom Designs strut tower bars-YES
•Prothane polyurethane control arm bushings-SELLING BOTH CONTROL ARMS WHOLE
•Prothane greasable swaybar mount bushings custom adapted for use on car-NO
•Koni Sport Kit suspension giving a 1.5 inch front drop and 1.75 inch rear drop-NO
•SP Performance nickel coated drilled and slotted brake rotors-NO
•EBC Yellowstuff'R Brake Pads-NO
•BFG drag radials at the track-NO
Interior
•B&M short shifter-NO
•Black Corbeau FX1 racing seats-NO
•Black 5 point harnesses-NO
•Interior accent painting-YES
•Blitz Turbo Timer-NO
•Lotek 3 Gauge A-Pillar Pod -NOT YET; ALREADY SPOKEN FOR LOCALLY IF I DECIDE TO SELL
•Stewart Warner 0-100PSI Fuel pressure gauge-NO
•Stewart Warner 0-100PSI Oil pressure gauge-NO
•Stewart Warner 600F-2200F EGT gauge-NO
•Stewart Warner 30inHg/40PSI Boost gauge custom mounted behind steering wheel-NO
•Stewart Warner “Ultra-Shift Light” digital tachometer / shiftlight combo custom mounted behind steering wheel-NO
•Sparco Mugello steering wheel-NO
•S&W Racecars 5 point roll cage system-NO
Other
-Full dash and Center Consule (as-is)
-Stock seats (2)
-Rear seat if I can locate both halves
-Spare tire and jack LOL
-Carpet
-Glove box
-Engine wiring harness (non- ABS)
-In car wiring harness (power nothing plus sunroof currently)
-Headlight wiring harness
-Tail light wiring harness
-Stock spoiler
-Wings West Commando spoiler with light harness, missing hardware when I bought ($80 minimum)
-Gauge cluster
-ECM
-BCM
-Glass if I can replace with Lexan cheap enough
That's all I can think of for now. You gets get the picture now? LOL
5K PB: 24:50
10K PB: 54:26
