average between edmunds.com and kelley blue book value is $6800.00 for an 01 in great condition. I took that and half of the 9,119.00 in mods which is $4,559.00 combine the two $11,359.50 A Steal at $10,500.00 buy it now. obo Buying a home and have done everything I have wanted to with the car except the internals of the motor.
Price list of modifications 01 Z24 turbo
· 2002 GM Crate Motor = warranty
· Just rebuilt 4t40e trans with 4t45e clutch packs and newest pump design no wave washer = ebay winning bid of 500.00
· Yank 2800 RPM Stall Converter = 240.00
· Secret Hybrid Cams 150.00
· Polished T3 Super 60 Turbo .48 Turbine / .63 Compressor 60 Trim. Supports 340 HP= 500.00 vecco.net
· Modified & Milled down Internal Wastegate Swing valve Assembly < Boost comes on at about 1800 RPM's. = came with turbo vecco.net
· HKS Super Sequential Blow Off Valve = 240.00
· ATP Turbo feed line restrictor =40.00
· Superchager 310 CC High Impendence Injectors = 215.00
· Ford Green Top 440 CC Injectors =160.00
· Cartech Billet 2025 FMU = N. A .
· Camaro LT1 Fuelin.com Adjustable Fuel Pressure Regulator =119.00
· 2 Bar GM Supercharger Map Sensor = 130.00
· Extra 2000 Z24 Auto PCM Reflashed with GM Superchager Program= 150.00
· Walbro HP 255 LPH Intank fuel pump = 130.00
· Johnny Race Car Front Mount Intercooler 2.5" in & out Polished 200.00
· Custom Stainless Steel Log Style Manifold polished = 300.00
· 2.5" Downpipe wraped in Thermotec Insulation Wrap and Sprayed with 2000 Degree Paint
· 2.5" Test Pipe
· 2.5" to 4" Straight through HKS Style Muffler
· Casper 02 Simulator
· Magnaflow 2.5" High Flow Catalytic Converter ^^^ the above 5 items = estimated 500.00
· Jegs 100 psi fuel pressure guage on fuel rail =20.00
· Wideband 02 Air Fuel Recordable Computer =350.00
· Auto Trans Interceptor 149.95 rksport.com
· 2.3 Liter High Output Throttle Body 50.00
· High Output Manifold 100.00
· Mantapart AC elimanator pulley =N. A.
· Stainless Steel Feed Line 59.95 vecco.net
· Stainless Steel w/ AN Fitting Return Line = A Team oak forest Illinois 80.00
· Polished Turbine Housing Cover vecco.net 84.00
· Dual Port Wastegate Actuator 88.00 vecco.net
· Turbonetics Manual Boost Contoller 52.95 vecco.net
· Fully Show Polished 2" / 2.5" / & 3" Charge Pipes =350.00 insanity customs oak lawn illinois
· Blue Hose Techniques Silicone Connectors = at least 200.00 check prices on hose techniques site
· SS Hose Technique T Bolt High Pressure Clamps = part of above 200 hose techniques
· Polished IDI Twin Cam Cover 150.00
· Always use Mobil 1 5W30
· Digital Innovative Motorsports Recordable Air Fuel gUage 220.00 carcustoms.net
Suspension/Wheels/Brakes:
· Eibach Sportlines 1.7" and 2.3" drop =230.00 tire rack.com
· Stocker Struts
· power slot slotted rotors = n. a.
· Adjustable Camber kit =n. a.
· 17" Silver Exel TZ 10's
· Nitto 450 Extreme Tires = wheelmax.com 1200.00 above two.
Interior:
· white hvac cover 20.00 high rev motorsports
· White Speedo Cover 119.00
· White fog light cover 15.00 high rev motorsports
· Boost guage 43.95 eguages.com
· Oil Pressure Guage e gauges.com 43.95
· A/F guage 43.95 eguages.com
Exterior:
· Keep it simple and Sleepy
· 02 LS Non Sport Bumpers Front 150.00 private seller
· LS Sport Rear 150.00 private seller. Paint for both was also another 150.00
· VIS Evo Carbon Fiber Hood = vis 500.00
· Tinted Windows = ziebart tidy car lifetime warrantied 230.00
· Clear Corners rksport =59.95 rksport.com
· Shaved trunk lid . no tails stock wing or lock 120.00 private seller will include with sale.
· Silvania SilverStars pep boys hate to say. 30.00
· Altezza taillamps rk sport 185.00
TOTAL 9119.00 not including misc 1000.00 for welding , fabrication time , fluids and what not. over 10k invested. purchaced new in 01 and was only a daily driver for one year. it is a weekend car for me but it is now time to move on to more serious things.
<img src="http://img.photobucket.com/albums/v292/dragmyz24/shoppedcav2.jpg">
Rush Racing
http://www.gettherush.com/
