I have an 03 l61 2.2 ecotec. Was wondering if cams from the 2.0 or 2.4 would swap to my 2.2? If so is there any advantage? If so how much of an advantage?
2.0 lsj cams will not work as the exhaust cam is larger. Le5 (2.4) has vvt and will not work either.
Comp makes various grinds for the l61.
You could cut the end off of the 2.0 exhaust cam to make it work but it's not going to be worth it without boost.
"In Oldskool we trust"
And even with boost, the difference is marginal at best.
Exactly what these two veterans said!
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
