lloking at possibly upgrading the ignition in my 02 circle tracker. just the 2.2 standard deal, but im looking at putting msd/accel coils with maybe accel wires. my question do i need to change any control module or anything or will the coils bolt on and direct plug in?? ive done a search of the forum and not much comes up.
If you find a direct fit part you can put them on pretty easy. If you're not able to locate a fit for your application, then you'll need to do some fan work.
*fab work. I'm not as familiar with the 2200 as I should be, but I think you can just replace the coil on that one with your msd and wires. No need to swap out any other modules unless you're vying for a lot of power.
I have a 4 cylinder msd race box if you wanna buy it.. you would need coils and wires additionally.
MSD makes coil that will directly swap for a LN2 motor.
