Engine problems - Performance Forum
Engine problems
Tuesday, May 12, 2015 3:45 PM
First off sorry if this is in the wrong forum but I have a 2004 cavalier ls sport and when I take off in 1st 2nd and sometimes 3rd gear it sputters really bad. Has anybody had a similar or same problem. There is no check engine light or anything. I replaced the coil pack and spark plugs but still Does it. Please help I need my car for school and work thanks to everybody in advance.
Re: Engine problems
Wednesday, June 17, 2015 2:55 PM
Have you tried cleaning the injectors and TB?
Give it a seafoam treatment and see what happens.
Also take out your plugs and look at them, replace if needed.
Re: Engine problems
Wednesday, June 17, 2015 2:56 PM
Might be your clutch going , you have a 5 speed?
Re: Engine problems
Wednesday, June 17, 2015 9:22 PM
Have you hooked it to a obd2 reader might have code but engine lights not working.
Re: Engine problems
Thursday, June 18, 2015 7:11 AM
I agree with Michael, however I had a similar problem and it happened to be my throttle position sensor!
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
Re: Engine problems
Sunday, June 21, 2015 7:58 PM
Check all of the above but also check your fuel pressure, if its a little low it can cause a hesitant take off. It might be fine at an idle but drop when you give it gas.
WHAT DO YOU MEAN I NEED TO TUNE MY CAR?
