2.3 Intake Manifold > 99 Z24 - Performance Forum
Sunday, March 23, 2014 9:56 AM
With ALOT of fabrication to making the manifold fit, finally get to the throttle body and the one that came on the manifold was a backwards setup for the throttle cable. So had to go bolt up the stock throttle body to the 2.3 manifold. Long story short. Went to start it and it just Reved up to 3.5 grand and i turned it off.
Keep in mind intake is not on yet
My question is why would it rev up like that? Could it be the TPS? Any help would be appreciated ^^
Get Wrecked
Re: 2.3 Intake Manifold > 99 Z24
Sunday, March 23, 2014 11:15 AM
vac leak
Monday, March 24, 2014 3:25 AM
Sparkey05 wrote:vac leak
Agreed.
Monday, March 24, 2014 6:54 AM
Agreed.
x3
Whether at the throttle body or manifold flange to the head.
"In Oldskool we trust"
Tuesday, March 25, 2014 5:23 AM
You've got a pretty bad leak for that thing to rev that high. You definitely don't want to run it like that at all, as you'll run extremely lean.
Wednesday, March 26, 2014 8:24 AM
Cool, Thanks... Found out it was leaking around the bolts to the head from the manifold. My friend used washers on the bolts because he had to drill out the holes on the manifold to make it fit. Turns out we really didnt need the washers in the first place and now my bolt on the head is stripped. F%ck!
Get Wrecked
Wednesday, March 26, 2014 9:01 AM
GIRLSp33d-Z wrote:Cool, Thanks... Found out it was leaking around the bolts to the head from the manifold. My friend used washers on the bolts because he had to drill out the holes on the manifold to make it fit. Turns out we really didnt need the washers in the first place and now my bolt on the head is stripped. F%ck!
I do not agree at all with pretty much all of this.
Washers help distribute the clamping force of the bolts, or the studs. Either the bolts were over tightened, or you didn't buy longer bolts or studs for the added thickness of the quad manifold.
Wednesday, March 26, 2014 9:55 AM
I indeed did not buy longer bolts, the stock bolts are 40. What length do u suggest i try?
Get Wrecked
Monday, March 31, 2014 3:24 AM
The longest that will fit into the head and not bottom out.
