James Cahill wrote:There's really only two things you need, and it's easy. Access to a computer and www.j-body.org. That way you can either use the search function or simply go to the 3rd gen forum and read the sticky about it. If you don't have a computer, or can't get to www.j-body.org, I would suggest going down to one of the big box stores (Best Buy, etc) and picking up a cheap computer. Heck, you could even do all your research right in the store, in which case, you could either use their printer, or the good old, tried and true method of pencil and paper. If you do end up buying the computer, take it home, set it up, then connect to the internet and go to www.j-body.org. Everything you want to know is there.
Yes, that was sarcastic. Seeing your join date, then seeing you asked this question, be prepared for much more of the same, but from plenty of other people. My first reply is free, but I charge double for the second.![]()
