2.4 fuel rail on ecotec? - Performance Forum
Monday, April 01, 2013 8:11 PM
I was curious if any knows if you can modify a 2.4 fuel rail to fit on a ecotec, reason asking is because I just purchased a 99 z24 yesterday with a bad engine but already has a fuel gauge added to rail and adjustable fuel pressure regulator. Getting all my turbo parts lined up now for when I do ecotec swap and figured if it can be done it would be nice for turbo setup. I know lines would need some work most likely, but least of my problem as long as physically rail itself could be used.
FuzzMASTA9
Re: 2.4 fuel rail on ecotec?
Monday, April 01, 2013 10:25 PM
To my knowledge, no.
Why not just drill and tap the eco rail for a gauge (easy 10 min job) and weld on a AN fitting and run a line to the AFPR?
Tuesday, April 02, 2013 4:52 AM
I was more concerned about the afpr than the gauge, know it only takes couple minutes to drill and tap rail for that. The afpr is the style bolted right onto rail itself thats why I was thinking of using whole setup. Probably gonna just end up selling rail setup and just buy a nice AEM afpr instead and run all new fuel lines instead.
FuzzMASTA9
