We r running a cavalier on a 3/8 mile dirt track. We keep getting a rod knock and are on our third engine. I know the 2.3 oil pump will most likely remedy this. For right now though we were thinkin about changing to synthetic oil or maybe even thicker oil. Just looking for some reccomendations
If your considering staying on a stock motor I would run extra oil . Being circle track the oil is being force around the pan and might not be getting picked up properly.
Building a motor with a 2.3 oil pump, or a dry sump would be better.
2.3 oil pump and clevite 77 bearings are the way to go... Synthetic oil is thinner and will find the leaks quicker...
Lucas Oil Additive!!!
But if you can 2.3 oil pump swap...you will love how quick it will rev.
GMR has got nothing on this
DOHC_tuner wrote:Lucas Oil Additive!!!
sorry, but ewww no. no oil additives are needed. that stuff is not good. bob the oil guy proved that
-Z Yaaaa- wrote:ive wondered this myself.... why cant we say run 5 quarts instead of the 4.5? does it come blowing out the dipstick tube or something?
Just more wear on the parts that have to deal with moving the extra oil.
i run seven quarts myself, but thats to get the oil to the full mark on the dipstick...
Cruisin4DrCav wrote:-Z Yaaaa- wrote:ive wondered this myself.... why cant we say run 5 quarts instead of the 4.5? does it come blowing out the dipstick tube or something?
that i can live with. ill go dump an extra half quart in mine right now LOL
and im with vince... why lucas? its basically just really thick oil. why not just run a thicker oil if your going by that theory?
Come join us over on the Olds Quad 4 and Twin Cam Facebook group!
I think when dealing with the stock ld9 oiling system running 5 quarts maybe even 5.5 quarts will not have any ill affects.
For a higher mileage engine the clearances become higher and higher til needs a rebuild. I think this Lucas just helps holds it together something like super glue that even a thicker oil will still lack. Pus this helps reduce friction somewhat like a synthetic, yet a lil more sludgy.... I when I say this im not talking about Pennzoil. Lol, stay away. I've talked to a tech that raced engines and he said the Quakerstate engine was really clean and the other Pennzoil engine was sludged
one thing i think we can all agree on is everyone loves their oil they use and there will always be stories about the ones they dont.
i use wal-mart super tech in my beretta and it's never been a problem. i have always used valvoline in my quad motors and have never had a problem.
-Z Yaaaa- wrote:one thing i think we can all agree on is everyone loves their oil they use and there will always be stories about the ones they dont.
I can agree with that.
I also think it is important that you stick with 1 oil and of course regular service.
Well we got the engine in and went with synthetic 5w30. We will be going thicker on the first oil change after next week. The car run great, but as with all 3 engines we have put in it, it has a blow by issue still. We were blowing a lot of smoke going into and though the turns so now we run an oil catch can off the oil air seperator to keep it from entering the intake and combustion chamber. That was sufficient until last weekend. Now it is overflowing and getting everywhere and he car smokes. Its mounted on the passenger side and I'm thinking we should try movIng it to the driver side and maybe centrifugal force might slow down the oil travel as well as ne t weeks thicker oil. We started lastnight with 1/2 quart extra oil, but ended up just puking it out of the catch can filter. I guess no more extra oil.
I am new to the dry sump oil pump and only know so much about it. Sounds interesting, but I dont really know whats available for our cars. Looks like time to do a search unless someone can direct me to a good starting point.
We have a couple extra blocks layin around in the gararge, so we were gonna try and see how successful we would be at drilling out the passages for the 2.3 pump swap. I've been wanting to try this for some time now as the oiling system seems to be the weak point in running this engine on the circle track. One thing I have just recently been wondering is does the 2.3 oil pump swap eliminate the balance shafts? I never really thought to question that until now since I am seriously considering trying the swap. I figure that is how it will rev faster without the extra rotational mass.
Brad, you got any bungs left to do the swap?
You can fill too much. Once the oil gets up to where the crank counter weights are rotating in it you are reducing power and running the risk of cavitating the oil.
yes, the 2.3 swap removes the balance shafts.
You could fill a motor with the front timing and cams removed and see how much oil it takes for the crank to come in contact with the oil.
YOUNG J wrote:Well we got the engine in and went with synthetic 5w30. We will be going thicker on the first oil change after next week. The car run great, but as with all 3 engines we have put in it, it has a blow by issue still. We were blowing a lot of smoke going into and though the turns so now we run an oil catch can off the oil air seperator to keep it from entering the intake and combustion chamber. That was sufficient until last weekend. Now it is overflowing and getting everywhere and he car smokes. Its mounted on the passenger side and I'm thinking we should try movIng it to the driver side and maybe centrifugal force might slow down the oil travel as well as ne t weeks thicker oil. We started lastnight with 1/2 quart extra oil, but ended up just puking it out of the catch can filter. I guess no more extra oil.
Ask, and you shall receive
http://www.overkillengineeringmotorsports.com/
Well, I'm asking. Any information you want to share is more than welcome. I gotta figure out a way to quit spinning bearings on the track. its getting expensive replacing engines every couple races. 8 weeks of racing and we are on our third engine. So yes, hook me up!
Brad, I thought I remember seeing a gp about an adapter to use a different oil pickup with the 2.3 oil pump in order to retain the 2.4 oil pan.
you could also modify the 2.4 oil pan... having 7 quarts in there is nice...
well they cant always do that sort of thing in the racing world.
but yes, young j... there is an adapter that does allow the use of a stock pan. pm me for more details on how to get one.
I choose the technology built for land speed records... not the technology built to save on emissions and gas mileage.
My LD9 ran 15W50 Mobil one, for 100K.
5 qts.
'02 Z-24 Supercharged
