Hello ppl, new to the forums...I've owned my cavalier since 07, its a 2.4 2000 cavalier...Its basically bone stock, only thing ive done to it was install a SRI.
I have a question regarding intake manifolds, i searched but seem to not find anything...
I was At my local auto junk yard and found this on two of the cavaliers...
Is that a different intake manifold? is it better than this one? VVV
That is the 2.3 Quad 4 manifold. If you want to use it, you'll have to buy a phenolic spacer/adapter from turbotechracing.com.
Is that a pic of the actual engine u found? might be worth checking that out a little better...it maybe a 60mm...cams...lifters...ton of stuff that could potentially and would be better for the ld9, the tranny would be worth getting even if only for spare parts, I mean IF thats the actual motor/trans and IF they give you a good price, and IF you even want to do some upgrades to your car--I had a hard time finding an isuzu trans that wans't destroyed, almost got the newer getrag and converted because of the scarce parts
Roofy wrote:That is the 2.3 Quad 4 manifold. If you want to use it, you'll have to buy a phenolic spacer/adapter from turbotechracing.com.
actually I think you just have to modify it a bit....I THINK, but i'm fairly confident there is an article about it somewhere on here, like Zyaaa said just check around a bit, should find what your looking for...that mani "should" be better though
If you're pretty stock I wouldn't bother going to the 2.3 manny.
If you've got a decent build going on, it might be wise to swap to it.
________________________________________.
Still not low enough for a signature.
those pictures are from the internet....the cavalier that i saw at the junk yard were complete, like no one even touched it under the hood
Only thing i took was the z24 emblems and side skirts but when i saw the manifold i wanted it...I mainly want it just for looks, if its a simple bolt on with light modification i can do it...
The cavalier is stock
Just want the engine bay to look nice.
So both bolt on just need to make the holes match up?
