a/c delete? - Performance Forum
a/c delete?
Tuesday, May 29, 2012 3:22 PM
How would you completely remove the a/c in a ld9?
Re: a/c delete?
Tuesday, May 29, 2012 3:56 PM
remove the compressor, lines, condenser, accumulator, and evaporator.
Re: a/c delete?
Tuesday, May 29, 2012 7:32 PM
Does Amy of that tie into anything else? Like coolant lines?
Re: a/c delete?
Tuesday, May 29, 2012 8:13 PM
nope. there is the electrical connection at the compressor, but that's it.
Re: a/c delete?
Tuesday, May 29, 2012 10:10 PM
Yea. Should i just tape that off? Or cut it?
Re: a/c delete?
Wednesday, May 30, 2012 3:25 AM
Everything removed weighed 33 lbs when I took it all out on my 99 z24.
Re: a/c delete?
Wednesday, May 30, 2012 4:39 AM
Awesome. That compressor is a Damn boat anchor.
Re: a/c delete?
Thursday, May 31, 2012 7:00 AM
What bolts are you guys using for the tensioner pulley then? Since the original bolts go through the AC.
________________________________________.
Still not low enough for a signature.
Re: a/c delete?
Friday, June 08, 2012 6:57 AM
still not gonna make your car fast i would leave it there
JBO since July 30, 2001
Re: a/c delete?
Friday, June 08, 2012 7:11 AM
Twenty4z wrote:What bolts are you guys using for the tensioner pulley then? Since the original bolts go through the AC.
Two options:
Ghetto fabulous it and put nuts/spacers in... or go get new bolts that are the right length.
Regardless... why remove the A/C on a street driven vehicle? It's totally understandable for a race or track car because shaving lbs is cheaper than adding horsepower... but I'll never understand you guys giving up simple creature comforts so you can get to the next stoplight .01 seconds faster.
Now if you're removing it to install a supercharger down there... well then...
-Chris-
-Sweetness-
-Turbocharged-
Re: a/c delete?
Friday, June 08, 2012 8:39 AM
I'd say to keep it too if at all possible.
2004 Cavalier Sedan
Re: a/c delete?
Friday, June 08, 2012 7:55 PM
My whole a/c system is shot. I didn't want to spend the boat load of cash for a new compressor, radiator thingy, piping, and colector canister thingy for something I've never had on any of my previous cars. I was already bypassing the a/c compressor with a smaller belt so why not remove it while the motors out? Now I have two pipes coming from the firewall. Is it safe to take those out or is there fluid in them?
