Ok i have a 99 cavalier z24 2.4L my flex pipe is messed up and the dealer cant get the bolts out of the manifold so instead of trying to find a good used 1 or spending 200+ for a new 1. Ive decided to just put on a some pacesetter headers , but im confused because ill still need a flex pipe im guessing and the flex pipe doesnt look like it will bolt up to the headers like the origional manifold would bolt up at the 3 bolt flange. So if anyone has a layout or advice on how to install the flex pipe with this header id appretiate it. Im just trying to get the concept in my head so i can buy the parts im not wanting to spend more then 300 on the set up. i know thats cheap but yea thats all i want to sink in it. Thanks
the header replaces up to the factory cat. has it's own ball-flange flex, which you'll want to install polyurethane mounts to keep from cracking.
Thanks sorry for the noob question never messed with headers before , im kind of learning as i go with this car. Do you happen to have a example like a link of some of those poly mounts that might work with my cav? it would be much appretiated
