So I'm sitting at my desk at work going over the last few little parts needed for my build. For some reason Spencer's vert popped in my head and I started thinking about his HO water outlet.
I change the plastic ones like every other year, no big deal.
I really hate the metal line that runs along the back of the exhaust cam tower and would rather it be braided SS hose.
I know I can tap the plastic housing and get a -4an adapter and thread it in but would rather have an aluminum one.
I know the 2.3s had the aluminum version that used a paper gasket for sealing rather than the oring.
Has anyone actually used that housing on a 2.4 head? I don't see why there would be an issue but would rather check with the masses to see if its been done.
Ion2 made a custom aluminum one that looks great, but I cant get one made for less than the $28 the auto part stores want for the HO one.
This has been gone over just recently on here. People are using the 2.3 ones, but I do not understand how you people are having issues with the stock one. All the 2.4's I have owned or worked on never seen one fail.
Oh they break, trust me. I had to do a middle of the night run to autozone while my car was stuck in a crackerbarrel parking lot after the water outlet split in half while driving.
I wish i still had pics of it, literally cracked in half.
I havent had a problem with one since then, but i think i would rather have an aluminum one as well
Eat my shift
No Longer Screaming wrote:This has been gone over just recently on here. People are using the 2.3 ones, but I do not understand how you people are having issues with the stock one. All the 2.4's I have owned or worked on never seen one fail.
I did a whole forum search and didn't find any mention if someone running a 2.3 outlet on a 2.4.
M2 wrote:Oh they break, trust me. I had to do a middle of the night run to autozone while my car was stuck in a crackerbarrel parking lot after the water outlet split in half while driving.
Hey mike, I think thats the one I have sitting on my bench in the garage. It literally looks like it was cut in half.
That because the4 search function on this site sucks balls!
lol the search works great... you just gotta be smarter than it.
So I finally received my 2.3 water neck the other day. I ordered it for a 93 GA HO. This is what I got and it doesn't look like it will work.
Gasket against 2000 2.4 head:
2.3 Water neck openings at head:
Look though:
Head ports are separate:
I trying to remember here, but what about 88-89 ones? Honestly I can not really remember though.
From the looks of it, it could be made to work with a tap, a plug, and a drill.
Thats kind of what I was thinking. Tap and plug the small hole and drill a passage between the large and small hole. There should be enough meat left around the hole to bore it out for a 3/8 npt flush plug.
Quad4 thermostat housings are a strange looking piece.....
I will be picking up some flush plugs tomorrow and will try this after work.
