I know the knock sensors are diff on 96 LD9 vs a 00 LD9. My question is are they the same as far as the ECU is concerned? I know they are physically diff sizes and have diff plugs, but do they run on the same voltage and act the same? Meaning can I simply splice in one another's harness/plug to use them rather than retapping the block? I'm using a 96 motor in a 00 and would like to keep the 96's sensor as is (except plug) if possible.
12.6 @ 114.6 MPH
no... they have different amount of wires... you have to run the sensor to match the PCM... which means you need to bore and retap or install a helicoil (depending which way you are going)
Do you know what threads each uses, or better yet, where to find an adapter? The 96 seems to be close to 1/4NPT but I don't think that's quite it and the 00 is smaller than 1/8NTP.
12.6 @ 114.6 MPH
You need to buy a special fitting that will let you put the 00+ sensor in the 96 block. I cant remember the p/n or website but it wasnt expensive. PM a member on here called Zyaaaa Im 90% sure he has the correct info.
Do a good search and you will find some post on this.
Awesome. Thanks. You the man.
12.6 @ 114.6 MPH
Love that gif! lol
I was going to need this for the block I was using for this build...... but since I got to happy with the drill, I'll use the other block now
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Brad ur the man!
Now I wonder if I will need this for my 99 block out of the alero for my 02 z
GMR has got nothing on this
