Not to be rude but search...I searched "2.2 rocker arm" and selected "exclude replies"
THIS was the third on the list.
i comp cams 1.6 roller rockers in my 96 2.2
Summit-Want to split a set??????
May bee...
We only need 8 so a 16 should be good. Only thing I'm worried about (same as anything I'm ordering online) is fitment. Is it he right ones for our cars and stuff like that. I'd like to know what other members have on their cars and buy that, cause I know it'll fit. It's already been tested.
So people... please post your aftermarket rocker arms here (part numbers preffered)
Thanks
________________
Greater Moncton Sport Compact Club -
Facebook -
Youtube
you need to have 3.1 v6 studs i do know that.
my comps did, but they came with the kit from mantapart back in the day
Its all listed by Madjack's thread I'd also like something nice. everything I've priced is about 250. for 16 [just rockers] you do need new studs and you need to grind several areas on the valve cover for clearance. If you do want to split a set PM me.
Has anybody looked into the rockers used on the Series-II 3800 V-6? They look like they might slip right over the shoulder of the '94-'97 LN2's stud. Plus, they're already form a torque-to-yield app.
Go beyond the "bolt-on".
Hmmm.....
This was posted-
Zs Z wrote:Not to be rude but search...I searched "2.2 rocker arm" and selected "exclude replies" THIS was the third on the list.
and it gives you all the part numbers.
I'm sure the How-To is somewhere on JBO, but I went to Google, typed in "2.2 rocker arm swap" instead and found-
This How-To (which is copied from the grand daddy of the rocker arm swap How Tos) as the first link.
I see nothing in there about grinding the valve cover, and every other bit of info you could possibly need. All that in less than the 6 minutes it took Zs Z to respond to your original post.
I did this swap on two different engines, directly following the How To I just posted. No issues.
MonctonCavi (OneNickyG) wrote:Why did Mantapart have to close...
They closed because they sold @!#$ products, had terrible customer service, and we all hate them. I think you should spend a bit of time looking around here
