I was wondering what kind of ignition systems everybody on the org was running especially on the ecotecs
i have the 2200 ignition setup with msd coils on my 03 ecotec
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
Factory baby.
Stock, and even at stock spec plugs it almost never breaks up with 13 psi being crammed in there. I will be switching to 2 steps colder and gapped down once the new plugs get here. Theres absolutely no reason to upgrade your ignition until after you've needed to upgrade your rods and pistons.
Sponsored by:
Kronos Performance
Have you guys not seen pj's car? Any modded car can benefit from an upgraded ignition, whether its be a built/boosted setup or bolt on n/a.
MSD dis-2, and external coil setups are popular. I had a 2200 coil/icm with msd wires on my ld9, or you can use msd interface modules and msd 8224 coils, or other 2-tower universal coils.
icemike89 wrote:Have you guys not seen pj's car? Any modded car can benefit from an upgraded ignition, whether its be a built/boosted setup or bolt on n/a.
This ^ ^ ^ ^ ^ ^ ^ ^
I wouldn't have it any other way for my LD9 and went from my factory setting of .045 gap (that's what it worked best at that time) to the full blown .060 with the MSD setup and relocated coils.
I eventually plan on an individual coil setup as a final ignition mod.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
I have the 2200 swap and plan on upgrading to MSD coils eventually.
stock here
Sig thanks to bxmobkrazey on gmscf.com
im boosting soon, whats the best ignition upgrade i can get. (15-20 psi) on low comp pistons and eagle rods. with valvetrain, cams, and full 2.5 exhaust.
