03 ecotec injestors - Performance Forum
03 ecotec injestors
Wednesday, June 02, 2010 7:56 PM
Ok so im sure you guys all heard this 100s of times but im wanting to upgrade my injectors but im not sure which ones to get and what i will have to do to upgrade. I.e other things i will need. i ordered a comp cams stage 1 cam set and have a header and highflow cat and catback in my garage all ready to be put on. im looking to do it all at once but i want to get bigger injectors. any suggestions???????
Re: 03 ecotec injestors
Wednesday, June 02, 2010 8:08 PM
cobalt ss (lsj) injectors are a good upgrade (36#), and a lot of the cobalt guys upgrade them pretty quick when they pulley down so u can get a used set for pretty cheap.
Wednesday, June 02, 2010 8:15 PM
ok thanks. is it a direct replacement or no. and i know i will need a tune after correct?
Thursday, June 03, 2010 6:20 AM
Yes you will need the tune altered, It's a very quick/easy adjustment in HPTuners to change the injector constant for larger injectors.
Thursday, June 03, 2010 8:41 AM
ok so to get the injector constant changed i need to get hptuners?
Thursday, June 03, 2010 8:49 AM
I'd like to add that cobalt injectors are shorter than one's found on the 03-05 j's...you will either need to swap an 02 eco fuel rail or grind down the blocks on the bottom of the fuel rail and slot the mounting bolt holes.
Thursday, June 03, 2010 9:45 AM
JUCNBST wrote:I'd like to add that cobalt injectors are shorter than one's found on the 03-05 j's...you will either need to swap an 02 eco fuel rail or grind down the blocks on the bottom of the fuel rail and slot the mounting bolt holes.
True.. for my 2002 LN2 I had to oval out the holes on the fuel rail bracket (for mounting bolts) and bend it a lil to accomodate the stubby injectors... in my case it was a very easy modification.. even considering I had to solder in the SS injector clips onto the wiring harnes. But this was for an LN2, not an Eco.
Thursday, June 03, 2010 11:14 AM
I have had success running 2 of these washers under my injector cups and not touching my fuel rail.
Thursday, June 03, 2010 11:35 AM
I'm just gonna confirm Tinkles that using the washer DOES WORK. Ive been running them on my 05' Sunfire for about a year with SS injectors.
Re: 03 ecotec injectors
Thursday, June 03, 2010 11:49 AM
so i can use my stock fuel rail with ss injectors and washers?
Thursday, June 03, 2010 12:17 PM
injector head spacers along with accel injectors worked for me on the 03 rail
Thursday, June 03, 2010 12:20 PM
Which accel injectors?
Thursday, June 03, 2010 12:24 PM
That is what im going. Stock 03+ fuel rail, Cobalt SS/SC(LSJ) injectors, 2 washers under each cup, and everything is nice a snug w/o any leaks. I have been running over a year and a half like this.
Thursday, June 03, 2010 12:31 PM
ok thanks tinkles i think thats what im gonna do.
Thursday, June 03, 2010 4:12 PM
i took out 1/4 of an inch on my fuel rail of my 04 to run the ss injectors made my check engine light come on but my motor was stock when i did it but besides the grinding of the fuel rail they fit perfect i bought mine off ebay for $40
Thursday, June 03, 2010 6:21 PM
any pics
