Am looking to finish my exhaust system. Running things like this:
Pacesetter header --->
Catco high flow cat --->
2.5 magnaflow catback --->
18" glasspack resonator.
If that setup is going to be raspy, (
other than running a longer resonator) will a different brand high flow cat or resonator make a difference???
Thanks in advance!
Spalattero wrote:
Pacesetter header ---> Catco high flow cat ---> 18" glasspack resonator ---> 2.5 magnaflow catback
Fixed. That should reduce the rasp decently.
Personally i would use a longer resonator, because i absolutely hate rasp.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Tinkles wrote:Spalattero wrote:
Turbo ---> Catco high flow cat ---> 18" glasspack resonator ---> 2.5 magnaflow catback
And I fixed that for you, that would eliminate any rasp at all lol.
Seriously though, I would put the longest res you could fit under there right after the cat. Also if you wanted to change the muffler(Ive never been a fan of magnaflow) super turbo mufflers would be quieter, and something like a dynomax unltraflow would be deeper and every setup Ive heard with this muffler wasnt raspy at all.
am not looking for amazing results as my car will only get bolt ons for a while. two questions:
1. can i just get a "universal" magnaflow high flow cat
2. can i run a SECOND resonator further down the piping?
Replied to your pm
Yes a universal magnaflow cat will work, just get the correct sixe piping you need. If its going on the end of your pacesetter youll need the 2.25" unless you have a custom dp made for your header.
Yes you can add a second res but one longer one would be better and more cost efficient.
I have often thought of installing a system that uses the longest glass-pack possible between the cat & muffler on my ride, with the addition of a resonator tip, to see how quiet I could get it's note. Money keeps me from exploring it, but I can assuredly say that a 22" Cherrybomb & Dynomax Super-turbo do the job very well. Nice deep burble w/o a hint of raspiness. A pleasure to the ears at all times... Even when rollin' down the highway for long periods.
Go beyond the "bolt-on".
Header, Glass pack, 2.5" EXT, DYNOMAX MUFFLER.
Chris
'02 Z-24 Supercharged
Atomic Turbo Header, .63 a/r turbo(soon to be .82 a/r), 3" downpipe, flexpipe,
this resonator
I replied to your PM also... and I realized I was wrong... you might want to go with a longer res than that LOL 18" would be the smallest I would go.
And heres my setup.. (2.4 engine with 5-speed btw)
Pacesetter header, magnaflow cat, 23" cherry bomb for a resonator, pacesetter monza cat back..
This is an older video of the car but all the engine mods and exhaust parts are the same as I have now...
Its mostly all WOT but if you turn your speakers up you can hear it when its not..... (and never mind the squeaks and rattles LOL)
First run with windows up, the second is with them down..... this vid was also taken after the glass pack broke in all the way.
This is my setup and I think it @!#$ rocks the house, it's super quiet at idle and part throttle, WOT it sounds a bit throaty and mean, louder but not enough to set off alarms.
Tsudo header ---> Magnaflow 2.5" cat ---> 28" Thrush glasspack resonator (it barely fits, you can get shorter ones) ---> 2.5" Dynomax Ultraflow SS (straight though design)
Don't buy from MANTAPART!!
There is no easy ways to get HP, no magic box or gizmo... And if you get more hp, there's no way to make your car still behave and sound like a stock one. More hp usually makes your car louder, more vibrations and harder to drive...but still people hope or think maby there's some magic way to have it all, comfort, stock sound and drive.
Do you have a video of your setup fastfiretwotwo?
]:-> 287 TimeSlips In Hand. Car Still Runs Strong... 3 Differentials Later ]:->
Weebel wrote:I replied to your PM also... and I realized I was wrong... you might want to go with a longer res than that LOL 18" would be the smallest I would go.
it sounds pretty good. am looking to get more of a smooth/deep tone rather than the growl. ty for the input!!
FastFireTwoTwo wrote:This is my setup and I think it @!#$ rocks the house, it's super quiet at idle and part throttle, WOT it sounds a bit throaty and mean, louder but not enough to set off alarms.
am interested in the video too. maybe just a few revs with camera back of the car.
Am set on a Universal Magnaflow cat..
Round or
Oval???
RESONATOR, help!!!!
- Angled OR straight inlet/outlet?
Cherry bomb OR
thrush magnum?
- 2.25 OR 2.5 inlet/outlet?
As far as mufflers go...
No vids or recordings, sorry, no time..take my word for it, hahahahaha.... Oh and no resonations inside the cabin... you have to lower window to hear it... this is a plus for me, but some people actually like hearing the exhaust drone on inside the cabin...
My setup...
Pacesetter header ---> Catco high flow cat ---> 2.25 aerospeed muffler ---> no res.
Raspy as HELL. sounds like crap. LOL
