Can anyone tell me if the Unorthodox crank pulley is the same size as the stock harmonic balancer or will I need a new belt. Might actually get a chance to do my cams this weekend and I figure that while I have the balancer off I would replace it with the underdrive. Thanx in advance.
Was afraid of that. Thanx
Copy of install PDF from Unorthadox Racing.
Click Me
FYI....Uses Gates belt K050450
Your welcome....if you have any questions feel free to ask. My phone number is on the ohio j-body site.
Is there a chance that I will run into the same problem that "the01cav" is running into with the jtune pulley causing low volts through the alternator? MD - the install page on Unorthodox website says that I should be equipped with a steel sleeve that the oil seal rides. I bought my pulley on ebay almost 2 years ago and all that the seller sent me was the pulley itself. Do you have any ideas how I might remedy this or should I just contact Unorthodox? Thanx again
Yes, you could run into problems at idle. Got a pick of the snout end of the pulley?
Are your sure its an unorthodox pulley and not a OBX rip off?
^^^ yeah no crap. OBX is good for leaving out the small details THAT MATTER.
ef why eye... its not a 'balancer'. the engine is internally balanced. its just a crank pulley, something to drive the accessories.
and to comment on the power drain issue... most have the issues while using BOTH underdrive pulleys. a lot get away with using just the crank pulley without an issue. another thing to point out is if your car is fully loaded with every option than it MAY have issues. if not than i am almost 100% positive it will be just fine. headlights are going to dim at idle though no matter what, thats just a given.
Are you scared of the changes coming? The answer is on the inside.
Its Unorthodox. Just called it a balancer cuz that is whay its called in Haynes manual. I know its just a pulley. And my car does have all power options. I guess worst case senerio is that if I have power issues then I just go back to stock. Thanx for the input tho
/img]
I think I need to fix the date on my camera
It seems to have the sleeve. You can kinda tell by the difference in colors where the different metals meet.
I think you are right. I checked it with a magnet and the mag sticks to the surface that rides the seal and around the snout. Thanx so much. Would have never even thought to check that if you wouldn't have said something. Now to get the belt and get this thing on my car.
well you can slide it on the crank, if its all sorts of wobbly than obviously it aint got it.
that'd be another way to check.
Yeah, I'll figure it out. Thanx sirs
