Any one have one? or know where to purchase?
well you can paint it yourself if you want that done...
personally, i had mine powdercoated.
You look so much cuter with something in your mouth.
with the heat generated from it, i would not do either..
z yaaaa wrote:personally, i had mine powdercoated.
One of these days, if he's still willing, I am going to send an alternator to Brad so he can take it to the place that did his and have it re-built and powder coated black for me.
EVOFire {DesertTuners} wrote:with the heat generated from it, i would not do either..
honestly, it depends on what paint you use.
polishing works on it too without a problem. only people I would even suggest either for would be the 2.2 LN2 guys as ours are right on the top.
Brad - I'm curious as to how the powder coating is holding up to it. and did they do it properly by sealing the inside of the casing?
Try chroming... It's been done before.
Go beyond the "bolt-on".
Heat makes no difference with Polished or Powdercoated Alts.
Either is fine, Ive had 2 ALTs Polished.
2012 numbers - 4SPD
AUTOMATIC!!
WHITECAVY wrote:EVOFire {DesertTuners} wrote:with the heat generated from it, i would not do either..
Agrred. Just keep in mind if you go the polished route it is going to require constant polishing to keep looking good. For that reason I would reccomend getting it powdercoated.
By the way I have seen Brad's alternator in person and it is amazing!
the powdercoating has held up outstanding on it and heat isnt an issue whatsoever, thing is... its only got about 5000 miles on it so the 'wear' really isnt a factor.
and j to envy- absolutely, anytime you are ready, im game.
here's a pic of mine...
^^^ Very nice.
-Aaron
www.TurboTechRacing.com
z yaaaa wrote:the powdercoating has held up outstanding on it and heat isnt an issue whatsoever, thing is... its only got about 5000 miles on it so the 'wear' really isnt a factor.
Man I tried like hell to get the housing off one and ended up screwing up the shaft. Is there anyway to do it without a press?
Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
^^^ honest to god man im not sure. i gave it to my dad who has been a mechanic for 30+ years and even HE didnt wanna mess with it after trying to get it apart. i dont recall the shaft being the issue though... i believe it had something to do with some connections inside being soldiered together with some he-man super sh!t that a normal soldiering iron couldnt even touch. i just said screw it and took it the place that rebuilt and powdercoated it. the the end it was the best thing to do.
why not do ceramic?? i had my alt. case ceramic coated with the same stuff thats on my header while i had it apart getting the internals beefed up
..obviously the ceramic can take any heat the alt can put out...heres a pic..
awesome.
so thats ceramic eh? so is the intake, idi cover, and upper mount block support brace?
