I have a 1998 Cavalier Z24 with the 2.4L. It has OBX Headers and Ram air intake. But I have no top end any ideas. I dont have a lot of money to spend. What about Cams!
Well performance mods cost alot of money...so either get ready to spend the "lot of money" or just dont do it.
Otherwise you can get some secret cams for cheap. This cam swap would probably be the cheapest route to got with.
And while your in there P&P the head. More to mention but like I said it cost money!
GMR has got nothing on this
That sounds good. I also heard of an acceleration Booster, any Ideas, I don't think its worth it. But I got smoked by a stock z24 with only an "acceleration Booster".
"Acceleration booster"? I am assuming youre talking about the intake temp resistor mod? Those are BS, I would assume there are other factors in you're loss in that race...
What do you consider "A lot of money"?
"A car just isn't a car without a little blood, sweat, and beers." -- Shadowfire
I only have a couple hundred max. would like took keep it cheap if possible. I also have a lot of time to make more.
How can a remove the governor so it will go beyond 110 mph...
Ryan Phillips wrote:I only have a couple hundred max. would like took keep it cheap if possible. I also have a lot of time to make more.
you dont need to go that fast
Ibtl
The proper way of using the word seen. It is not I seen it that would be I saw it. He has seen the car is the right way to use the word. English class is Cool. By the way thats my sig
I would research.
In the time it takes you to properly research, and develop a plan, you can be saving money.
That way you'll have the money then the knowledge on how to make the car faster.
With the mods you have, you're never going to go over 110(thats not to say the car cant do it). Doing so other than at a track is illegal, and you wont go that fast in the 1/4. (currently)
Edited 1 time(s). Last edited Thursday, November 06, 2008 4:40 PM
Ryan Phillips wrote:How can a remove the governor so it will go beyond 110 mph...
Talk to a tuning shop that has HP Tuners... know it will cost nearly $500 - 600 depending on the shop, and unless your car can break 110 in the quarter mile, there is no legal purpose of removing the governor, and is not recommended.
Also FYI... you have an OBX Header .. using "headers" implies you have a v shaped engine and run 2 headers. in line 4 cyls only have one header.
Edited 1 time(s). Last edited Thursday, November 06, 2008 9:22 PM
Lets just say your not ready to go past the governor.....you need to upgrade your suspension and brake system before you get that far otherwise your just asking to flip over. And dont even mention Nitrous....cause your not ready for that either!
I have KYB struts and Eibach drop springs.
Ryan Phillips wrote:I have KYB struts and Eibach drop springs.
thats not enough
Wow....
another post about limiter removal....yeah!!!
and IBTL
KYB AGX or GR2s????
What about sway bars, strut bars, control arms, bushings...
when you replaced the struts and installed the springs, did you get new mounts or use the factory ones??
theres a lot more to a suspension than simply lowering it.
2.4L have top end. it just doesnt seem like it becasue they have sqaure torque and horspoewer numbers. they also dont quit till almost redline so i dont know why ur complaining about top end. if u think the 2.4L is bad try driving a 2200 2.2L. but if your really want top end still, a bigger exhaust will move the power band higher up. cams too. cam swaps are NOT a cheap mod.
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
Toronto Cavalier wrote:cam swaps are NOT a cheap mod.
And they arent getting cheaper...
the LD2 Exhaust Cam (Secret Cam) is discontinued and $330 from GM's obsolete warehouse
i got the secret cam swap for less than $100 at a local u pull it yard.
I have Kyb AGX with 2 " drop.
Front Strut bar
I can do my own work just need to find Cams.
couple hundred.....could go talk to a performance shop and see if they could P&P the Throttle body for ya. give ya only about another five horse, but with later mods could be sufficient
Ryan Phillips wrote:I have Kyb AGX with 2 " drop.
Front Strut bar
that still aint good enough to handle over 110 mph. we are talking about shock, springs, bushings, sway bars, sturt tower bars, everything. then of course there is a little system called the brakes
99redz24 wrote:i got the secret cam swap for less than $100 at a local u pull it yard.
yea... you could do that if you want used parts... =P
Front Strut bar
Thats it???? you need to do a bit more to be safe above 80 Mph.
JBO Chat User: SpeedlineZ wrote:99redz24 wrote:i got the secret cam swap for less than $100 at a local u pull it yard.
Front Strut bar
they are cams. its not like they are going to be worn out
F*Ck You It handles fine over 90 mph. All I asked was how to get there faster.
