Pistons 2.2L - Performance Forum
Pistons 2.2L
Tuesday, September 16, 2008 1:37 PM
I have a 94' Cavalier. It has the 2.2 4 cyl. I circle track race on a 1/4 mile oval. I am in the process of rebuilding the engine and I have been told that I could use 98' pistons in order to gain compression. Also, this could be done without modification. I was wondering if this would help me any or if I could get more "bang for my buck" somewhere else. Thanks in advance for all answers...
Re: Pistons 2.2L
Tuesday, September 16, 2008 2:49 PM
Read the thread in here by Bob Guptill. Is it possible? Yes. With no supporting mods? F_ck no.
Re: Pistons 2.2L
Tuesday, September 16, 2008 3:40 PM
Where can you purchase forged pistons for the 2.2L then. i have a 95. and cant seem to find anywhere that sells them.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road
Re: Pistons 2.2L
Tuesday, September 16, 2008 5:34 PM
Any piston company will make a custom set of forged slugs to your specs.
Buying off the shelf ones would limit you a lot, because when it comes to our cars off the shelf pistons generally have a narrow range of overbore and compression specs.
Re: Pistons 2.2L
Tuesday, September 16, 2008 6:28 PM
That's gotta be pretty expensive though. Even though everything for this engine will be expensive.
Re: Pistons 2.2L
Tuesday, September 16, 2008 7:10 PM
Check with Karo for pistons:
carcustoms.net
He should be able to get you any bore/CR you need.
11 speaker JL Audio stereo setup for sale:
http://www.j-body.org/classifieds/audio/52021/
Re: Pistons 2.2L
Tuesday, September 16, 2008 8:35 PM
i buy custom flat tops from ross racing $600 per set with rings, but you need eagle rods with them as the smallest pin they offer is .830 so the small end on the rod needs to be honed out.
1998 pistons can be put in a 2.2 just do not shave the head at all, we have a guy running them fine with a 1996 fuel injected cavalier but with my motor that had a lot more done cam wise and a lot of head shaving they did not fare to well to say the least
Re: Pistons 2.2L
Wednesday, September 17, 2008 3:01 PM
So if i got the eagle rods and the pistons from ross racing i wouldnt have to hone it or i would?
Re: Pistons 2.2L
Wednesday, September 17, 2008 5:23 PM
You're dealing with an engine that's how tired and you're asking this? Really...
Go beyond the "bolt-on".
Re: Pistons 2.2L
Wednesday, September 17, 2008 6:03 PM
Does it matter if my engine is older. I would rather put the parts on this engine while im learning how to mod. so if i screw something up and the engine goes i can do a swap for something newer.
Re: Pistons 2.2L
Wednesday, September 17, 2008 6:30 PM
Genius: I meant the engine is probably very worn from however many miles it's seen since it rolled off the assembly line, and I'm guessing alot if it's from a '94 J-car (Re: somewhat heavy car (4-dr), 3-spd trans (If Auto) that's seen highway use) it's pretty tired. I bet it's got about, what? 100,000-nearly 200,000mi on it (If not more)? So in short: Odds are you'll need to hone it for the sake of trying to get the rings to seat properly. So, yes... Hone it!
Re: Pistons 2.2L
Thursday, September 18, 2008 12:38 AM
the ross pistons i have the part number for are for a.030 overbore
Re: Pistons 2.2L
Thursday, September 18, 2008 12:48 AM
^ Or, as in the case with of the pistons Bob speaks of, Bore it!
Re: Pistons 2.2L
Thursday, September 18, 2008 1:21 AM
the ross pistons are wroth the money if you are going to keep the car a while, we snapped an eagle rod in half before we screwed up the piston. i have destruction pics of the toooo
Re: Pistons 2.2L
Thursday, September 18, 2008 1:39 AM
And what is that P/N, Bob? And for the rods too, while you're at it.
Re: Pistons 2.2L
Thursday, September 18, 2008 10:13 AM
teh rods are the eagles sold for the ln2 part number CRS5590C3D
the pistons are number 100779
those are flat top pistons so any of you guys going boosted dont use them
and like i said ross' smallest pin is .830 and the rods are made for a .804 stock cavalier pin so a machine shop has to bore the brass bushing on the small end i can get some pictures of the pistons i have
Re: Pistons 2.2L
Thursday, September 18, 2008 10:22 AM
Pictures would be awesome.
Re: Pistons 2.2L
Thursday, September 18, 2008 12:30 PM
Yah, I got Custom built wiseco pistons for about that same price $540 or something.
I got my rods from carcustoms.net
http://www.carcustoms.net/product_info.php?cPath=266_23_135_608&products_id=395
Re: Pistons 2.2L
Friday, September 19, 2008 5:20 PM
here are the pics of my flatops and the broken eagle rod
btw we only allowed this much destruction to happen because we were leading on lap 28 of a 30 lap race, the next corner this happened, we had no oil pressure from the start of the race
