problem - Performance Forum
problem
Sunday, August 10, 2008 5:47 PM
i have a problem of course. my check engine keeps intermitting. like going off and on occassionaly. i do know they my code is telling me that i have too much air and not enough gas. so it running lean. can anyone tell me what elas i can do like up grade the injectors or passible my fuel filter is clog. i change my fuel filter a year ago. any suggestion would help.
Re: problem
Thursday, August 14, 2008 10:48 PM
code 300 and 171. both 02 senors are new, no vacum leaks, replaced spark plugs and coil pack. ill change out the fuel filter when i get some money, not that hard to do. i have yet to check the injectors.
Re: problem
Friday, August 15, 2008 8:20 AM
P0300 - Random/Multiple Cylinder Misfire Detected
P0171 - Fuel Trim too Lean (Bank 1)
You will definitely want to check your fuel filter to make sure it's not clogged, check your fuel pressure in the lines, and make sure your injectors aren't sticking close by bench testing them.
Let me know how it goes.
-Steve-
