fuel rails mods - Performance Forum
fuel rails mods
Tuesday, April 22, 2008 12:07 PM
looking to replace my stock rail for he venom but i also want a adj fpr which one will mate up with no mods?????
THERE CAN BE ONLY ONE, i have already died once and im still here so lets just leave it on the track
Re: fuel rails mods
Tuesday, April 22, 2008 1:53 PM
Your stock fuel rail is more than capable of the flow you need. LT1 FPR's work on our cars. I have an accell reg on mine right now that was made for the LT1.
-Chris
Re: fuel rails mods
Tuesday, April 22, 2008 2:18 PM
IamRascal wrote:Your stock fuel rail is more than capable of the flow you need. LT1 FPR's work on our cars. I have an accell reg on mine right now that was made for the LT1.
lLT1 huh? and that mates right up with no mods
Re: fuel rails mods
Wednesday, April 23, 2008 6:13 AM
Have you searched? There are tons of people on here using that afpr....myself included. No mods necessary.
Re: fuel rails mods
Wednesday, April 23, 2008 7:27 AM
Accel Adjustable Fuel Pressure Reg. ACC-74565
I believe that is the right P/N
Re: fuel rails mods
Wednesday, April 23, 2008 9:49 AM
this is my search for input on whos using what and how its working for them
Re: fuel rails mods
Wednesday, April 23, 2008 11:20 AM
there is only one option if you dont want to modify anything.
accel AFPR....thats it.
option 2: leave the stock fpr and cut-in and AFPR downstream.
option 3: tap the rail to get rid of the stock fpr and hook up the aftermarket one.
Re: fuel rails mods
Wednesday, April 23, 2008 1:06 PM
Im running an AEM universal with a homemade rail (option 3+).....works great as any other ^options would.
Re: fuel rails mods
Wednesday, April 23, 2008 2:23 PM
i want the venom rail and a adj fpr i plan on some form of boost in the near future
Re: fuel rails mods
Wednesday, April 23, 2008 2:29 PM
Yo, all you had to do is look on page 2 of this forum..
http://www.j-body.org/forums/read.php?f=2&i=408875&t=408875
Re: fuel rails mods
Wednesday, April 23, 2008 4:03 PM
so i'm guessing my spare fuel rail is going to disapear soon.
Re: fuel rails mods
Wednesday, April 23, 2008 4:28 PM
SCZ2400 wrote:i want the venom rail and a adj fpr i plan on some form of boost in the near future
you DONT need the venom rail for boost. the stock rail, i believe, is good to about 400 whp.
Re: fuel rails mods
Thursday, April 24, 2008 11:07 AM
ya but the venom rail look kooler lol
Re: fuel rails mods
Friday, April 25, 2008 9:18 PM
With the Venom fuel rails, you should be able to use AN lines to run to an externally mounted afpr of your choosing.
This really shouldn't be a problem if you want something completely custom.
If you're going to stick with the stock fuel rail, the above afpr by Accele is the way to go.
That's the setup I'm using now and have the fuel pressure reduces to about 35 psi over the stock 43psi that the factory is set at.
I've got better a/f mix with this pressure and the short/ long fuel trims have improved too.
Good luck with your project.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Re: fuel rails mods
Monday, April 28, 2008 5:39 AM
^^^you still have to get the venom tapped to run AN lines
Re: fuel rails mods
Monday, April 28, 2008 7:44 AM
whiteboyz24 wrote:^^^you still have to get the venom tapped to run AN lines
Really, damn I thought they came tapped.. grr.
Re: fuel rails mods
Monday, April 28, 2008 8:24 AM
It shouldn't be too hard to tap.
Just tap with NPT thread and use an NPT to AN adaptor to be able to use AN lines.
That's what I plan on doing with mine once I get off my lazy butt.
Misnblu.com
