Injectors?? - Performance Forum
Injectors??
Tuesday, March 11, 2008 4:15 PM
I have a 2.4L fully built motor. I was just wondering if i could go with bigger
injectors to get some more hp out of the motor. It currently has stock injectors.
Thanks for reply in advance
Re: Injectors??
Tuesday, March 11, 2008 4:19 PM
I dont know if this should be in the boost forum or performance. Too
late now!!! Just trying to get better performance out of the motor.
Re: Injectors??
Tuesday, March 11, 2008 4:38 PM
More info on your set-up. Bigger injectors (if needed) will not give you more power without tuning.
Re: Injectors??
Tuesday, March 11, 2008 4:43 PM
ya if ur considering putting this in the boost forum, im guessing ur s/c or turboed and u deff should have bigger injectors, the stockers will be maxxed out. im still n/a but i have bigger injectors tuned in with hpt, the stock ones were getting a bit close to the limit
Re: Injectors??
Tuesday, March 11, 2008 4:49 PM
weisco pistons
eagle rods
secret cams
.020 shave head
2.3L oil pump swap
56mm throttle body
N/a Just getting tired of getting beat by a neon
Re: Injectors??
Tuesday, March 11, 2008 4:55 PM
schmitzracing wrote:weisco pistons
eagle rods
secret cams
.020 shave head
2.3L oil pump swap
56mm throttle body
Car could probably use a good tune. Without datalogging the injectors hard to say if you need bigger ones, but maybe. I was getting close to maxing mine out and moved up.
Re: Injectors??
Tuesday, March 11, 2008 4:58 PM
Dont know much about hp tuners Is it more of just changing your RPM's?
Fill me in on what the tuners is all about. And what size injectors did
you go with same motor???
Re: Injectors??
Tuesday, March 11, 2008 5:03 PM
i have 320cc injectors in mine
Re: Injectors??
Tuesday, March 11, 2008 6:38 PM
I'm ryunning Cobalt SS/SC injectors which is about 368cc. HPT is a tuning program that allows you to tune the stock ECU. Go to the tuning forum and do some reading.
