Do they have a fan spray pattern? I ask, because I was reading about them and one place says to aim it towards the center of the piston, while another site said the oil strikes the cylinder wall and bottom of the piston to cool the piston. Unless it has a fan spray pattern, I don't see how one squirter could cool the piston evenly. However, looking at the shape of the tips of the squirters, they look like they would spray a narrow stream.
Any input would be appreciated. Thanks.
"Youth in Asia"...I don't see anything wrong with that.
bump
a) so ya like squirters eh?
b) they could have an internal needle/compressed in the rear to create a fan-like shape
Machzel08 (Teh Jew) wrote:a) so ya like squirters eh?
a) Indeed. The wetter the better
b) good point, but I would still like to know "for sure" how they spray.
grab a few and squirt stuff through them.
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
Performance engine builders usually pull those off of cars that come with them. A lot of DSM guys go to NA blocks to avoid them on builds.
OHV notec wrote:Performance engine builders usually pull those off of cars that come with them. A lot of DSM guys go to NA blocks to avoid them on builds.
Interesting.
Well I know they starve the main bearings of oil on some engines, which leads to failure. My guess is, that is probably the main reason the DSM guys don't like them.
Whalesac wrote:OHV notec wrote:Performance engine builders usually pull those off of cars that come with them. A lot of DSM guys go to NA blocks to avoid them on builds.
Interesting.
I know the k20 guys love them. One of the main advantages between a base model and a type-s rsx motor
brian...let us in on your secrets
this is a good debate to listen in on....
LE61T PTE6262 Powered
You refer to the 9000 RPM screamer?
We all drive in a yellow Cavalier...
AutoFreak57 wrote:Whalesac wrote:OHV notec wrote:Performance engine builders usually pull those off of cars that come with them. A lot of DSM guys go to NA blocks to avoid them on builds.
Interesting.
It was also an "advantage" on the turbo blocks.
Reasons are 1) They are a liability. If one comes loose, you're screwed. It's similar to removing balance shafts because of the belt.
2) Oil on pistons adds significant weight where you don't want it while you're revving (think of how many people add crank scrapers).
3) They work just fine WITHOUT them
IIRC chris (sweetnessGT) has oil squirters in his LD9.
I've always thought about using the SRT4 or Cobalt SS/SC ones aimed at the exhaust side of the piston.
You can coat the pistons with a oil sheding coating but it still wont act as tho you wern't throwing oil at them, you'll definetly know in your reving. The real question here is would they benefits out weigh the costs.....?
Good point, but a quad 4 oil pump is held on by 2 bolts, and if they come lose, then you will be even more screwed. I really don't see the likelyhood of the squirter's bolt(s) backing itself out under normal circumstances.
OHV notec wrote:2) Oil on pistons adds significant weight where you don't want it while you're revving (think of how many people add crank scrapers).
I don't understand your coorelation of oil squirters and crank scrapers. Crank scrappers' only purpose is to prevent windage from the reservoir of oil in the oil pan. You always have oil running down the cylinders into the oil pan anyways, now there is just a little more. The negative force the oil squirts exerts on a piston on it's power stroke will be negated by another squirters force on the compression stroke (in a similar manner as Crank Case pressures are evened out by opposing pistons...wtih the exception of air in the combustion chamber escaping past the rings).
i was just talking to my friend and he was saying the rsx guys take them off when they build. Not for reliability, but they are just not needed with aftermarket forged pistons. the new pistons can take so much more heat they are not necessary. Also, the extra oil pressure you get from removing them can help.
^100% exact and agree Notec
Squirters are only an advantage where detonation is likely to be a problem. Turbo diesels with high compression or 4 cyl engines looking for maximum power using the lightest possible components are good candidates for squirters. Just for grins, someone should look through the Eco*tec build guide and see if GM recommends 'em in the 1000 hp build formula. Anyway, with modern ceramic thermal barrier coatings and proper piston selection combined with good tuning, I'd predict there's no need for squirters on anything below 25 psi boost.
-->Slow
AutoFreak57 wrote:i was just talking to my friend and he was saying the rsx guys take them off when they build. Not for reliability, but they are just not needed with aftermarket forged pistons. the new pistons can take so much more heat they are not necessary. Also, the extra oil pressure you get from removing them can help.
DING DING DING.....im sure in very EXTREME situations they could benefit forged also
but the reason people take them out and block them off is so the mains can stay more lubricated and not starve them especially in high RPM applications
EFFICIENCY DETECTIVE
Fast cars. I respect them ALL. Brand elitism is for fanbois and benchracers
daily: 99 civic Si
deceased: 95 cavy '00 LD9 auto swap (vandalized)
