Well.... From a sad story or Mariusz(judgez24) z, comes some even sadder news, I recently purchased the bottom end of Mariusz to help my build out, A nice heat treated crank, knife edged, Eagle-H-Beam rods, Wiesco forged pistons, high flow oil pump, ARP Main studs, and a block with some decent work done to it, I thought to myself sweet !, AND I was glad to help out a great guy get something out of the tragedy that was this motor. Well.... the curse of JBP STRIKES yet again. All 3 pistons were demoed, the oil pump was wasted, and the block has become scrap
. The only slavage parts being the rods, crank, and main studs. and parts of the oil pump. NOW I am not mad at judge, the CRANK alone was worth worth what I spent so I am in no way angry at him, In fact im still happy with my purchase and would do it again, I took a risk purchasing knowing JBP had done this, so I knew what I was getting into.
NOW lets get back to the story of this motor. The whole sad part about all of this started back when Judge had JBP take 8 months, and to much money later to build him what should have been a GREAT motor. I mean, a done up crank, arp hardware all AROUND, Clevite bearings, H-beam rods, forged pistons, a done head, a high flow oil pump, a block with some oil passage work done.... This is a motor built to take power properly... Well in theory it is.....
You see all of this becomes USELESS if the motor is improperly assembled. You can spend 4 million dollars on parts, and still have it fail because of a half assed assembly. ASSEMBLY IS 80 % of the build ! SO please, in the future remember this when you tackle your own motor build. Take the time, and take the extra care to make it right. DO it right.
Now, how did Mariusz/Judge's motor fail ? YEP you guessed it. Poor assembly. Now let me describe to you what myself and 4 licensed mechanics discovered with this built motor. (one being a MT, the other having been a motor re builder, and the last 2 being really well rounded mechanics). and.. MYSELF... for what ever that counts......
1. All the main studs were placed in without any thread lock. (loctite) of any kind. This allowed for small movement within crucial pieces of hardware.
2. The "JBP HIGH FLOW OIL PUMP"... This is a decent piece, and it will work.. IF its assembled properly ! The pump was improperly pieced together, The little weird hex drive thingy (best way I can describe it, part of the drive assembly which powers the pump i guess), has a washer behind it, for what ever reasons this was not properly assembled period. It wore into the piece beside itself and caused a reduction in the engine oiling capacity.(From our best guesses) Thus depriving # 4 cylinder of oil. and causing complete failure. The other 3 pistons as well were marginally scarred, but #4 was utterly destroyed.(being the farthest away) The outcome is a pump that is scrapped, and a block that is finished..... and a toasted bottom end. (The piece responsible is circled.) TO top this, the motor was full of what I can best described as "metallic grey car oil paint lol". ALL the left over oil in every nook and cranny were infested with little bits of metal, very very fine, but everywhere, in the stud threads, over the rods, every where... TALK about friction and bad wear......
3. CLEAN CLEAN CLEAN !....... Nope not this motor, nothing was properly cleaned when this motor was built. at ALL, you could see that pieces were cleaned somewhat, (the block being acid dipped), and what not, BUT what good is this if you let it get contaminated during your building process ? This was yet again another contributing factor with this motor, and while it wasn't the immediate reason for its failure, it would have adversely effected the life span of the motor.
4. There were LOTS of other little tiny nits and bits to pick at, but what is the point ? these 3 points above are major mistakes. and caused this whole mess.
On with pics now.
http://img152.imageshack.us/img152/3782/0000962copyux6.jpg
http://img512.imageshack.us/img512/628/0000963copytp6.jpg
http://img509.imageshack.us/my.php?image=0000967copyfu8.jpg
http://img512.imageshack.us/img512/6241/0000969copyrs5.jpg
http://img104.imageshack.us/img104/6393/0000970copyzv8.jpg
My Cav
I give up...
