Ryan Shissler wrote:
Stock Crank? Is there anything i can really do to the crank to make it better? I know lighting it would but then i makes it weaker and im gonna get it balanced so all the weights added back on
quote]
Ryan when they balanced my crank they didn't add any weight to the lighter counter weights. They drilled holes in the heavier weights to make them all the same. And they bull-nosed it which lightened it some, and it did not hurt the integrity of the crank at all. Also you can bore your cylinders to 60 over. It might get hot if you do that. However I went 40 over on mine don't get hot at all. In fact my car runs cooler now then before when it was stock. But if your gonna turbo it I dont know if I would bore it much more then 20, however if you do you might be able to add more boost. But as far as boost goes I know nothing about that.
