Missfire problem - Performance Forum
Missfire problem
Monday, October 29, 2007 12:58 PM
Hi,
My mods are : 2,5 " cat back, without cat (cavalier 2005)
When I accelerate rapidly, I have constants missfires (running on 3 cyl), CEL flashing. So I have to drve like a grandfather...
I had the same problem when I had a turbo, blew an engine, bought a used one (12k km) and I have the same problem (without turbo).
Is that because I removed the cat? Or do I have an ECU problem? (constant CEL too)
I'm using new spark plugs and injectors.
http://aemecotec.monchar.com/
Re: Missfire problem
Monday, October 29, 2007 1:41 PM
from my past history with misfires, I would check the map sensor, and fuel pressure. (including vacuum lines and voltage at fuel pump with a digital meter. I had 2 volts drop with the stupid GM wiring.)
