valve cover vaccum - Performance Forum
valve cover vaccum
Friday, October 26, 2007 2:31 AM
think its okay to just cap off the vaccum line that goes from the valve cover to the intake? reason i ask is new intake doesn't have the nipple for the vaccum line. by the by car is an 03 eco
Re: valve cover vaccum
Friday, October 26, 2007 5:27 AM
for like $15-20 you can get a fitting set to add fittings to intakes. ive seen them at local performance stores.
1997 RedR - ZedR
Friday, October 26, 2007 5:42 AM
cap it off no... you need pressure to be able to escape out.
you can get a little breather to put on though and that will be just fine.
Friday, October 26, 2007 5:58 AM
you can drill a hole in the intake and put a gromet with a plastic pcv valve nipple.
~1996 Cavalier LS 2.4L (auto)
Friday, October 26, 2007 6:22 AM
Vacuum/ Sensor adapter kit
5, 8, 10 mm fittings with grommets
12, 14,17mm fittings with grommets
19 and 25mm fittings with grommets
sensor hole saw kit
there is a bunch of the spectre performance stuff links for the fittings and stuff. the first kit includes the hole saw and a few popular fittings, but doesnt say what size the fittings are.
it will probably cost you the same amount of money to by the fittings i posted above as it would to buy one of those breather filters. also, with the fittings your car would stay legal in the aspect that you are not by-passing the PCV valve like one of those filters would. some places it is illegal to by-pass the PCV valve as it is part of the emmissions system.
1997 RedR - ZedR
Friday, October 26, 2007 8:16 PM
^^^ that is true but Ecos don't have a PCV valve. The PCV system consists of a single rubber hose from the valve cover the intake (pre manifold, no engine vacum) and thats it. No valves but yes your point is the same and correct
