I'm needing the blueprint specs for a 2.2 ohv block. Mainly the deck height and housing bore specs for the mains. I was told some of the specs in the 2.0 GM build were incorrect. I searched but was unable to find thread. Any info or links are appreciated as I'm a newbie. Also any rod and piston combos for a longer rod setup, I'm interested in. I circle track and run in a narrow band at 8000 plus with a lot of throttle time, so a long rod setup would help. Thanks again, tbd.
"Power to the Pushrod"
As far as my '96 block, everything I've measured (deck height, bearing journals) matches the build guide.
-->Slow
Thanks slowolej and Extreme Delusions, I have read those threads. I still need specs for deck height, housing bore mins and max, compression height of the piston from pin to crown, and rod length. Thanks for your reply. tbd.
For deck height, you have to measure the block you're building. The specs in the OHV guide are listed as "nominal" for a reason... the actual values can vary.
The thread "Peer Pressure and the OHV" has values and specs I've measured or found by looking up various parts. If what you need isn't in there, post here agin and I'll see if I have it when I get home.
-->Slow
Kyle, thanks for those links, i've been looking for that page forever...
