I really need a new muffler and need some insight on what kinda one to get. not something to loud "baby on bored"
..... thoughts, suggestions, opinions?
2000 z24 Cavalier
so your saying i should just get a new stock muffler......or something roughly the same as stock untill i do my exuast. the one i have now is putting a little could it be the muffler or something else?.....the car used to idel really bad...but i put a ground wire kit and voltage stabelizer on it and it seems fine other than the little putting in the muffler.
2000 z24 Cavalier
that could be anything...
when coil packs go bad the muffler puts...
when the cam and/or crank position sensors go bad the muffler can put too
when the cat is clogged the muffler can put
IS the check engine light on, or does it blink at all while driving?
nope it's not on nor does it blink..... what does that tell me it could be?
and what exactly are the coil packs/ where are they located?
2000 z24 Cavalier
the coil packs are right under the IDI cover. (the thing that says 2.4l Twin cam) ... there are two of them inside the white box.
the coilpacks are ignition coils that send power through the boots to the spark plugs...
if your check engine light doesnt come on or blink at all, that usually means your sensors are good, and your emissions control systems are good (not always... but usually means this)...
most muffler shops also offer a free catalytic converter test... so that is worth checking out too...
all right thanks alot man that could save me alot of time and money!!!
2000 z24 Cavalier
