grinding w41 cams from blanks - Performance Forum
Thursday, September 06, 2007 7:16 PM
does anyone know of anyone doing this and selling them?
I have my 2.3 gtz torn apart and want to put it back together with w41 cams
also has anyone put ls1 springs in their 086 head I've heard there acctually a bit too stiff?
Re: grinding w41 cams from blanks
Friday, September 07, 2007 9:34 AM
I believe Comp Cams does cam regrinds (not from blanks). They are about the only place I can think of that could make you a "new" set of w41 cams.
I've heard of people using LS1 springs, but I think it was only on the OHV motors. Regardless, unless you are heavily boosted, I don't see the reason for stiffer springs than the stock 086 ones. If you aren't floating the valves now (and I would highly doubt that you are), then adding stiffer springs will only reduce horsepower. SS valves would be a better investment.
"Youth in Asia"...I don't see anything wrong with that.
Friday, September 07, 2007 9:47 AM
Car- part.com has plenty of exhuast cams on hand, but zero intake cams. im sure that one of the places with the exhuast's has got to have an intake, and if not... well, having the exhuast is better than nothing.
while there, look up 92 olds achieva then select w41 option when it prompts you for options.
Friday, September 07, 2007 10:00 AM
last i knew GM still had stock on W41 cams
Friday, September 07, 2007 10:02 AM
[quote=97cavie24ls(™)]last i knew GM still had stock on W41 cams
zoiks! i wondnt even have a guess as to how much they would be...
Friday, September 07, 2007 10:26 AM
.... i just got new ones for my GTZ.......(W41 cams)
Chris
'02 Z-24 Supercharged
Friday, September 07, 2007 10:42 AM
think they are couple hundred each
Friday, September 07, 2007 12:28 PM
isnt this the same guy that claimed to have w41 cam like a month ago?
Friday, September 07, 2007 6:18 PM
Yes paul the guy I bought my 98 z24 from rebuilt the engine and said he put w41 cams in it from his old scx.
2.3 cam towers machine hex drive on cam........... that whole debate
I am now looking for a set for my 90 gtz
by the way paul how is your z24 running ever get it tuned?
Friday, September 07, 2007 7:01 PM
i just got a set of new GM W41 cams for my 92 GTZ, MAKE damn shure there from a 90 W41, for some reasion, the part number is diffrent for 91.5 and newer LG0's... i have 1992 W41 cams, and it runs great.
Chris
Saturday, September 08, 2007 1:16 PM
do you remember the part number, I thought GM was sold out but maybe I'm wrong does crane cams make a set close tot he w41 specs?
