2200 vs. 2.4 Intake Mani - Performance Forum
Thursday, September 06, 2007 11:12 AM
This may comes as a stupid question but how far off are the two systems.
Would it be possible to take an intake mani and fuel rail off of a 2.4 and modify it SLIGHTLY to fit the 2200?
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Re: 2200 vs. 2.4 Intake Mani
Thursday, September 06, 2007 5:42 PM
the easiest way to see if the manifold will actually bolt on with a few mods is to compare the two intake manifold gaskets............The ports have to be the same or it will just cause a @!#$load of turbulence and the whole manifold swap would be pointless in the first place. then the studs on the head have to be pretty close also.
another question u have to ask is are the injectors the same between the 2.4 and 2200.... if the 2.4 has bigger injectors then it will run super rich
EFFICIENCY DETECTIVE
Fast cars. I respect them ALL. Brand elitism is for fanbois and benchracers
daily: 99 civic Si
deceased: 95 cavy '00 LD9 auto swap (vandalized)
Thursday, September 06, 2007 9:16 PM
yea good luck
ports are totally different, bolt patterns totally different, not to mention the intake is on the opposite side of the 2200 so it may hit the firewall
Thursday, September 06, 2007 11:56 PM
NO!
Friday, September 07, 2007 6:27 AM
Thanks for the info guys
Friday, September 07, 2007 5:24 PM
I thought they were different.
They look similar to each other but never knew if they would interchange or not.
Good information.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
